Third party software and hardware support forums. => Third party software and hardware support forums. => Topic started by: ftec on August 11, 2009, 06:16:37 AM
I'm using a Bosch router and at this point without speed control. How should I set up the spindle configuration in Mach when I simply want the router to be turned ON or OFF by the relay in either pin #16 or pin #1.
Thanks a bunch,
Risto
PS. Think I got it, just required reading further the manual. ::)
Anyone out there using CNC4PC C11? Setting up my system first with PC and C11 to see everything is OK and it isn't and have another problem. I'm using the pin 17 ie. Safety Charge Pump output to enable/disable our drives etc. The pin 17 low voltage keeps persistanty over 1.7 volts without being connected to anything. This is too high to change the state of the 7404 which I use as inverting buffer. Comments, hints previous experiences on that?
Risto
I'm not familiar with the C11 board. May be you could try contacting Arturo from CNC4PC.
Daniel
Daniel
Yes, done that, even called him over seas to his answering machine, no reply so far. Hopefully not the vacation month for him. Seems that the pin 17 goes low enough if set it's Charge Pump fuction off but not much point in that ...
He was on vacation last week. Thought he was back by now. He does reply emails though whenever he gets time.
I had a similar problem with the C1 board - a signal was not going low enough to trigger the schmitt trigger. I had to replace the resistors to temporarily fix that, before Arturo came up with a solution. So I think he is the only one who can help you with this one.
Daniel
Daniel
OK, must wait for him then. Some other problems arising as well. If might help if I had the pdf manual for the rev 6.1 but no manuals for the old versions on his site. (Well, if you can say a one year old card is old).
Always nice to see dealers who take care of their customers. Probably a manufacturing fault in the card and I will be shipped I replacement item.
Risto
Glad for you Risto. Arturo is really nice guy to deal with indeed. Ask him to test the new board before he sends it out though.
Daniel
I received a replament board of the lates version (9.3). It has the same fault in the pin 17 low voltage with safety chage pump on as it keeps around 1.6V and we need to drive TTL logic with it. Anyone out there who has found a solution to this?
Risto
Hi Risto,
I don't think it is the way it meant to be, so I'd suggest again consulting Arturo.
Daniel
Daniel,
I'm sure you are right as the manual promises around 0.4V for the output low voltage and thats what the other outputs have or less. Some other weird behavior with the pin 17 when the safety chage pump is set OFF as then the high voltage is only around 2.8V but low voltage is OK. I just wonder how folks have been able to use this card or perhaps they only needed a good high logic 1 and for low voltage just something which is 'not 1.'
Risto,
I think we could be having a communications problem. When you say SCHP on/off, it may not be clear if you refer to the software or the hardware. I will try to briefly summarize how this is supposed to work:
If using the SCHP, enable it in the software (enable SHCP on pin 17, port1) and set the jumper on the board to SCHP on. When the SCHP is enabled in the software (Mach3 out of reset) on the terminal for pin 17, you should measure +5vdc, when the signal goes off (reset), it should go to 0. This is setup this way, so you can use the output of this pin to enable other external devices.
If not using the SHCP, make sure it is disabled in the software; otherwise it will continue sending a pulse stream (that would explain the voltages you are measuring). If the jumper is set to off, terminal will behave like any other pin, it will send whatever is mach3 is sending.
If this still does not explain what is going on, please let me know, and I will send a wiring diagram for you to test a couple of voltages to see if the microcontroller is working ok and the test the signals as they pass through the buffers and optos.
My only explanation for you getting voltages between 1.6 and 2.8 is that the SCHP is on in the software and the jumper is set to have the SCHP on in the hardware. Those signals come straight out from a buffer.
Please also check that in the configuration window, the option for having the SCHP enabled during reset is off.
Arturo Duncan
http://cnc4pc.com
When I had the SCHP jumper set to OFF (1-2) position on the board I got a good 0V level and but 2.8V for the high. After I set the Charge Pump off in Mach as well I get good levels for both low and high so this works fine. Also the STEP and DIR pulses (5us) for the axis show very good levels and sharp wave forms with oscilloscope even at 100kHz Kernel speed (2.8GHz Intel Mother board) so I'm confident that we can sort the remaining prb out too with your support.
Risto
