Mach Discussion => FAQs => Topic started by: Notselrach on August 08, 2009, 11:33:19 PM
Title: How to change Configuration?
Post by: Notselrach on August 08, 2009, 11:33:19 PM
What switches in the configuration of mach3 control the on and off of the router?  My router runs exactly opposite so that before I start a routine I have to go in each time and change the gcode.  Otherwise, the router shuts off when it is supposed to start . ???........any help would be appreciated...Thanks
Title: Re: How to change Configuration?
Post by: Chip on August 09, 2009, 05:37:05 AM
Hi, Notselrach
It's probably the "Active Low" setting for your M3 CW Output pin setting, You should just need to change it's "State" I think.
Chip
