Mach Discussion => Brains Development => Topic started by: zarzul on August 03, 2009, 02:27:53 PM
I haven't done any brains yet but would like to try to do one.
I need to do an estop or reset based on a timer.
If I haven't hit the cycle start in 5 minutes I would like to shutdown the machine using the estop or reset button.
Can anyone give me a little help?
I don't know where to start?
Arnie
Hey Arnie,
Here is a Brian for you that does what you want. Note: you have to have "Enable1" (enabled in your ports/pins cfg). The logic is based on that one.
The screen shot, and Brian is attached.
scott
Scott,
Thanks for doing all the work!! I will try it out.
Arnie
