Mach Discussion => General Mach Discussion => Topic started by: simpson36 on July 22, 2009, 01:06:08 PM
Message similar to subject line every time I try to click soft limits on. >:( Been this way for a while so I don't remeber exactly when it started or what I might have changed just prior.
Homing works fine, all limit switches funtioning, machine is well within the homing/limits settings, with no limit switches triggered.
I tried disabling one axis at a time and then disabled all of them together . . . same error ???
Same error with Gcode loded or with no program loaded. Machine is running fine.
So it is not something glaringly obvious. Got me stumped . . . prolly something simple I am overlooking. :-[
A axis? Setting for that is on General Config page.
If not, then what do you have X and Y min and Z Max Soft Limits set to and which position is the table in when homed?
It does this whether the A axis is active or not, so we can take that out of the picture.
The machine homes all three axis to zero and goes positive from there in X and Y and negative in Z.
Clicking on RefAllHome works perfectly
I had the X axis converted to a photointerruptor for a while and I recently converter the Y and Z as well. Each axis limit switch is wired to its own pin. Hmmmm, now come to think of it, that IS a change that was made . . . I really can;t say if the error coinsided with the limit switch upgrades.
Does it make a difference if the limits are separated or on the same pin?
It is set something like this
Axis MAX MIN
X 9.8 0
Y 5.7 0
Z 0 -12.5
Using different pins wont hurt, thats the way my Bridgeport is set up.
All sounds fine so dont know where your problem lies, if you want to attach your xml I will have a look and see if I can find a problem.
Got it figured out.
Can't use more than a 30 bit number for limits. I had stupid huge numbers still in the A axis from the time before you enlightened me to the joys of SwapAxis.
Doesn't matter if A is active or not. Mach just pukes on the huge number if its there.
Thanks for the help, though. I owe you an Atholl Brose
LOL, will pass on that but thanks anyway :D
