Third party software and hardware support forums. => Galil => Topic started by: hydevillemfg on July 20, 2009, 11:20:04 AM
Has anyone had trouble getting the galil outputs to work configured as active low in the ports and pins screen? I'm running an 1832 card and need 7 outputs to be active low, one to be active high, but all function active high regardless of which way the boxes are checked... Thanks for any ideas...
It looks like the outputs don't take the active low config from Mach. I'll fix that up tonight. PM me with your email address and I'll get you a plugin that will work for you.
Steve
