Mach Discussion => Mach Screens => Finished Screens => Topic started by: giordano on July 02, 2009, 12:00:52 PM
Hello to all. I finally finished the new interface in Italian for Mach3. To install unzip the file setup.zip and launch the program setup.exe. Regards, Giordano Cantori.
Wheres the link?
Sorry .... Here's the link: http://www.machsupport.com/screens/Engscreenset_2.zip
Very nice work - :)
good mornig,
realy good screen for Mach3.
Thank you.
Dear giordano
There is no English translation at Job Control Screen. I see it is in Italian Language. Please translate and modify if it possible. Thank....
High Tech Key
Hello High Tech Key. To test, now I installed the translated version downloaded from the link provided and it works perfectly. Giordano
Dear giordano
I had already downloaded your Italian English screenset and testing. It is a great work. But you have left some translation for english at Job Control screen. Do you understand what I mean? My english skill is a little bad. So, I upload some picture for this screen. It is also left at "Set step per unit" button in "Setting" mode. I also upload this photo. Please translate and modify for this if you are OK. Thank.
High Tech Key
Hello, I'm sorry but I did not understand the problem. I had not noticed this oversight. Thanks for reporting. Attach the file to install updates. After unpacking the archive, rename the file setup.dat to setup.exe. Regards, Giordano
