Mach Discussion => General Mach Discussion => Topic started by: tinyron on June 24, 2009, 08:04:51 AM
Hi guys,
Has anyone used oris using an Express card parallel port for a laptop without a parallel port. Have you had any success or do they not work. Will a usb to parallel port cable work? is there anything else that ca work with a laptop without a parallel port?
Thanks Gents.
Ron.
Smooth Stepper which is USB is an option but as far as that card i don't know.
Thanks Rich,
Does it work in conjunction with Mach3 or a stand alone software package?
Ron.
SmoothStepper takes the place of two parallel ports and also gives you an additional 6 Inputs.
Thanks Hood,
Is it a software package or a device. Where do I find it?
Rgds Ron.
Its an external motion controller that connect to the computer via USB and integrates to Mach via a plugin, it can pulse up to 4MHz and can leaves the computer to concentrate on the trajectory planning etc.
Heres a link
http://www.warp9td.com/index.php?page=shop.browse&category_id=6&option=com_virtuemart&Itemid=33
Thanks Hood,
Have put my name on the wait list. Must be very popular.
Rgds Ron.
Yep, have them on all of my machines :)
Jeff Birt may have some in stock http://soigeneris.com/Warp9.aspx , presume you are in the USA?
If in Ozz or NZ then try Peter Homann, he may have them in stock. http://www.homanndesigns.com/store/
Hi Hood,
I am I Australia.
Will give the guy in Oz a Call.
Thanks hood. Have you encountered any dramas with them?
Ron.
Nope, did have a few issues right at the start but that was because I wasone of the Beta testers and it wasnt for sale at that time. There are a few issues with it still which I hear will be getting looked at shortly when the new Mach rev comes out. These things are no backlash, slaved homing and a few slight problems with FRO and slaved homing.
Hood, I recall you saying that swapaxis also does not work with SS.
Status on that?
Ah yes that doesnt work either but that might be working soon ;)
