Third party software and hardware support forums. => PoKeys => Topic started by: fast89 on June 19, 2009, 09:28:47 PM
I built a control panel with a bunch of switches interfacing with a pokeys. The only one i'm having problems with is the pause or feed hold. I've changed to different pins on the board, didn't work. I changed the keys from space to shift-f and it worked. Changed back to space key and it doesn't work. I can change the hotkey to anything i want but i would like to keep the space key as the hotkey. Am i missing something?
Sounds to me like you may have the space key assigned somewhere else to a different function. Could possibly be in your screen set.
it is still the original screen set that i removed/added a few things to. The space bar is only used for feed hold as far as i know.
Machscreen screen designer can be found in its on board that can help you find out if it is assgned to something else in the screen. Intall Machscreen, open your screen, go to view, hotkeys. Make sure it isn't found twice. Not just Ansi code, but the key its self. Make sure it isn't used in combination with a modifier key as well. Also make sure it is be use to imulate any thing in ports/pins, input/outputs.
looks like the space key is only used for pause on the various screens. I've found no modifiers with the space key either.
