Mach Discussion => FAQs => Topic started by: CharliePatten on June 19, 2009, 01:57:28 PM
Does anyone know how to hook up a remote cycle start button?
Yes,
You will need an Unused input on your: Parallel port, Modbus device or external motion board what ever your using.....
for arguments sake lets say your using Parallel port 1 and so you goto your ports and pins, and under inputs, scroll down until you see
OEM trigger #1. Put the Port1, and your Pin# that you have open.
Then goto: Config>System HotKeys Setup, under the External Buttons - OEM codes, under Trigger #1, put: 1000
then hit the OK button. OEM code 1000 is the button code for cycle start. so, when ever OEM Trigger1 goes hot, your cycle start button will "Press".
scott
