Mach Discussion => General Mach Discussion => Topic started by: PG Signs on June 16, 2009, 06:55:49 PM
Title: Problem with homing
Post by: PG Signs on June 16, 2009, 06:55:49 PM
When I try and home my router Z works just fine, then Y homes fine and when it starts to do X it acts like it is just trying to move the X motor and not the A that is slaved to it. The two run together just fine except when trying to home or reference the gantry in X. I have been through everything that I know to check (even though at this time it is not alot) and can not figure it out. I used the video on setting up the switches and soft limits and reviewed  it again to try and make sure I did not miss anything.
Jimmy
Title: Re: Problem with homing
Post by: ostie01 on June 16, 2009, 08:33:56 PM
Try in the Config menu, under the general config and check the Home slave with master axis
Jeff
