Mach Discussion => Brains Development => Topic started by: ftomazz on June 16, 2009, 04:53:58 AM
Hello.
Just want to know if the brain speed (number of times / time unit it is run) is in relation to the kernel speed.
I need a sensor to stop an axis, and the axis stops in a random position due to the fact that the brain does not process the input signal at the same time after the signal is high.
