Third party software and hardware support forums. => SmoothStepper USB => Topic started by: eloid on June 11, 2009, 08:44:06 PM
I m a newbie just configure my pc with mach3 with plugin and driver with smoothstepper software
as far as i can tell it went smooth.
I have one issue after reboot mach and loading it
I get a error in mach
Estop not assigned to smooth stepper input, its wire to port 1 10 and 5 v on bob just wiring diagram states
i have the smoothstepper providing 5 v to bob jumper
where do i need to configure this in the configuration in mach ?
Have you set up your ports and pins in config.?
i did that, and no long get the error....but have some other issues try to learn how to use mach is a learning curve
There is lots of information that may help in the documents tab at the top of this page and the video tutorials will help too.
I have few issues iusing Windows 2000 machine old desktop which i know is a bit slow but it only has windows
and mach on it, its a clean install , i did the drive test passes nicely,,,, I'm original assumption was the PC was to slow ( 400MHz pII)
so got my new laptop 1.6 ghz 3 g ram but i cant pass the drive test under vista did the vista upgrade etc
try the optimization txt for xp, can find one for vista? doest it exist?
I'm using the smooth stepper with both PC, when try use my c23 bob and smooth stepper, i assigned the estop to port 1 pin 10 just like the cnc4pc
describes..... estop is nc contact .... under diagnostic i get no led with hardware switch.... i know it wired right?
my question how do i know parallel port number is right... when i use the smooth stepper? is my port number not right? no luck with limit switches
to, using smooth stepper for bob power? bob led light is on?
when i use the motor tunning program i get no output xyz turned on im getting nothing, it must be a smoothstepper problem....
pls help
Did you install the SmoothStepper driver and plug-in? Also if your switching over an existing profile you have to tell it to use the SmoothStepper instead of the parallel port.
Mach3 doesn't use the driver when using the SmoothStepper, so it doesn't have to pass the driver test.
driver works.... smoother stepper not the issue its the c23 with the smooth stepper, driver work, plugins installed, smoothstepper selected in profile
[/quote]
[/quote]
i understand smoothstepper is not require under test, my question is there a optimization file for vista, the pc is new just has
basic install from factory, no other application installed try the windows xp .txt didnt help much... still very nosiy wave forms
You're misunderstanding. The Smoothstepper handles everything. No need to optimize the PC with the Smoothstepper. And no need to run the drivertest.
estop and limit switch working now ;D problem was with opto coupler having no power from smooth stepper c23 require
it from smooth stepper or external power..
now i need to get my motors working... there giving me isuues ??? :o
gecko drives g203s have green leds can hear them power up .. clunk sound, motor have good holding torq.
double checked step and Dir wiring, is OK, Dir from g203 to x Dir on output bob, step to x step on bob, com g203 to com on output bob.
c23 bob is set to com=+5v via jmp1 jump for gecko drive g203 drive
here is my screen shots maybe someone will see a issue
under vista the driver test wave look crapy, so i can ignore that?, im current run wim 2k no noise isuues with wave form
(ger21)
"The Smoothstepper handles everything. No need to optimize the PC with the Smoothstepper. And no need to run the drivertest."
Yes, ignore it. It's not being used.
help i need plenty of it New ss, New cnc4u C11, new geckos 320s, everything is Rosy. Well not rarely Z is perfect X and Y are all over the place they seem stronger in one direction and weak in the other , theykeep triping the geckos in one direction only
