Mach Discussion => General Mach Discussion => Topic started by: c+c on June 04, 2009, 12:28:06 PM
Hello,
I try to run Mach3 on a Asus eee touch computer.
When running Mach3 with standard screen set, it looks awfull.
I think the attached picture speaks for ifself.
Labels are sometimes so big, that they do not fit in the space available for it.
It makes a lot af the labels unreadable.
Do I have to configure Window XP somehow?
Couple things that will work:
-Resize the DRO's in Screen4 to the resolution of the monitor.
-changing your Font size in Windows to small
-Change the font type of the DRO's in Mach
-Use a Flash screen (they are vector based and will scale to any size shape and look clear)
But the screen set I used is ment for 1024*768. And my screen has 1366*768. So that will fit (with a empty space right to the window as you can see).
So I guess I should not change anything at the Mach3 settings.
I assumed the Windows fontsize was set to default, but I checked again. It was large!
So, Thanks! This solved it.
