Mach Discussion => General Mach Discussion => Topic started by: avirostick on June 01, 2009, 06:39:09 PM
Title: Thing ran fine, now jogging skips?
Post by: avirostick on June 01, 2009, 06:39:09 PM
Hi everyone. My Zenbot was fine for two months. In the last 2 weeks the Z axis was fluttering terribly when I tried to jog with xbox 360 controller.I checking the belts and bolts and everything mechanical, nothing out of place. I switched the cables from the driver to the steppers and found the z axis stepper worked fine when plugged into the x axis cable.  I then checked  in the motor configs, the z was different than the other two axes so I changed it and it ran flawlessly. Thought it was fixed, then after a few days, the x axis started doing the same thing. This time, I don't see anything off in the motor configs, and after shutting everything down, restarting, I can't get it working.
 I would just like to know, what would make the machine just go from working fine to this?
Title: Re: Thing ran fine, now jogging skips?
Post by: Hood on June 03, 2009, 04:41:49 AM
Hard to say, could be corrupt software or even you installed some new software that is making a mess of things, more likely however could be some bad connections or hardware problem.
 Is it a licenced copy of Mach? What version are you running?
If you attach your xml I will have a look and see if I can find a problem there.
Post by: avirostick on December 05, 2009, 09:17:37 AM
The problem was in the driver. Mechatronics products can be good, but probably not as secure as Gecko. I don't know what fixed it, but I changed some chips, and adjusted the current with the little phillips head adjustment deals in the driver and it was good.
