Mach Discussion => General Mach Discussion => Topic started by: tarik on May 28, 2009, 03:41:03 PM
Title: i want to scale ma design in mach?
Post by: tarik on May 28, 2009, 03:41:03 PM
       i want to know tf ther's a way to scale my design in mack,
i always have to change the size of my design depending on the need of my clients, and all the time, i have to go back to my cad and cam program, and post again.
is ther any way to scale my design without going back to my cad and cam softwares????
thank you.
Title: Re: i want to scale ma design in mach?
Post by: Hood on May 28, 2009, 03:44:26 PM
You can scale each axis with the scale at the side of the DRO, if you want X to be 10 times bigger you enter that in the box, if you want it to be 1/2 size you enter 0.5 etc.
Post by: tarik on May 28, 2009, 08:54:29 PM
i did it; i put 2 in that scale dro to make my drawing two times bigger, but it stays the same.
the default values of this dro are +1.0000, i changed it to +2.0000, nothing changed.
Post by: zealous on May 29, 2009, 12:15:32 PM
Hit "regen" to see the new size in the toolpath.
