Mach Discussion => Mach Screens => Machscreen Screen Designer => Topic started by: hdscarbro on May 28, 2009, 09:58:07 AM
I've been using machscreen and am overall very happy with it.
However, I noticed that if a screen has a locked background, drag select doesn't work.
Many editing operations can be lost because the save options is not enabled. For example, open a screen and move a label or led. The program does not think any changes have been made. Even worse, the "save" command is disabled so it is impossible to force save the file. In my opinion, save should never be disabled.
Also, it would be really handy:
1) If after typing a position into the properties dialog, the <Enter> key performed the same function as clicking on the "Position" button.
2) If multiple objects could be selected and positioned or resized through the properties dialog.
David
Hi David,
what program version are you using? The problems you mention, should all be fixed in version V1.20.
Klaus
I am using V1.20.0
A label must be selected and then moved via the keyboard arrows. Dragging with the mouse does enable Save.
It would be handy if there was some way to control the number of pixels an object is moved via the keyboard. Perhaps,
normal-arrow one pixel, shift-arrow 2 pixels, ctrl-arrow 5 pixels, etc.
Hi David,
in version V1.20.1 I made the following changes:
the menu item "save as" is now always enabled
moving selected items with the position keys: arrow keys moving 1 pixel, page keys moving 5 pixels.
Klaus
Ok, I am now part of the "I luv Klaus" fan club........ hehehe
Thanks again, for the new Toy...
scott
Awesome. Thanks, Klaus.
Thanks Klaus
Klaus,
I have a few aggrevational things.......
1). When you group select multiple items, 2 or more, because you want to then copy paste them, on the screen your working on. When you paste them they are Out of positional relationship with each other.
Also, when you copy objects and want to paste them onto the screen can you also make it where they will Drop where you click with the mouse?
currently there is 3 choices under the paste window, and none of them drop where the mouse is....
2). VB Editiing, the VB editing, (when you double click the VB line in the object properties window, and it opens the big VB window, can you put a "Done" button on it or something, it is very Unintuitive on how to get OUT of that window and back to the main window, further the Main window disappears, when you open the Big VB edit window and that is kinda scary. The first time it happened to me, I said, where the heck did my screen go? (panic, panic, etc.).
3). Object Drop: is there a way that when you select an Object type, like a button or LED or what ever than you can then Right click on the screen, and on the menu that pops up, you could select multiple Drop?? so if you need to place 20 or so Generic LEDs you could after that just right click and they would drop One on each Left click. When your done with the multi drop, you could then right click, and turn off multi drop, and that would make it once again a pick an object, then drop that single object, pick next object, drop it etc.
Some times, (for me at least), I will want to drop multiple buttons, LEDs, DROS etc. arrange them, then go through and define them.
Scott
Hi Scott,
thank you for your info.
1) I will fix this problem
2) In the file menu I offer 4 alternatives:
"Open file" to load data from a file
"Save file as" to give you the opportunity to save your data to a fie
"use data and close" puts the edited data to the set file
"ignore data and close" gives you the opportunity to cancel, which means leave your data from the set file unchanged.
If you close the editor window with the close icon an messagebox asks you "include data to screen set" yes / no / cancel, with the same results, as the menu selections.
3) You can insert objects multiple, one for each hit of the "add" button, when "place elements on mouse position is off". I will think about a solution for you.
Klaus
EDIT: If you have suggestions, perhaps different text or so. please tell me.
//////////// Ok, thank you professor
//////////////Ok, must have missed that somehow, thanks for the heads up..... I guess I am to used to buttons........
///////////// an option to drop copies of the same object over and over again at the mouse's clicked position would definaatly be a plus,
thank you for looking into it!
Klaus
////// I haven't looked, but, did you say that you can choose MS installed fonts as well as font size onto the screen....... also, one other
thing while on that subject. Can you make it where you can have "Multiline" on labels, or buttons?? or is that limited internally to mach3?
scott
Hi
version V1.21.0 is ready for download. In that version the paste problem is fixed. You can now place object repeatedly at the mouse position, when you keep the ctrl key pressed.
@ Scott just you frightend again ;D. Every time you start up machscreen, a copy of the actual set-file is set to the history-files. The file with lowest number at the file extension (*.se1) is the newest. You can rename that file to *.set and you have the version, before starting machscreen.
regards
Klaus
Thanks Klaus, I'll have to try to find time to play with it again later this weekend.
Hi Scott
Mach3 doesn't support multi line text. You also asked about individual fonts and font sizes in MachScreen. Also Mach3 gives you the opportunity to select a font and a font size, these parameters aren't stored in the *.set file. Since there is no way to store the font data in the *.set file, it makes no sense to implement in selectable font option in MachScreen, sorry.
regards
Klaus
I changed the help system to HTML, so all Vista users, can use the help - system. There is still a lot to be done. If you find errors, or funny English, please let me know.
Klaus
Hi all,
has anyone used the on line help function yet? I'm wondering, if the frame elements are in English. I would appreciate every answer.
Klaus
