Mach Discussion => General Mach Discussion => Topic started by: el4al on May 24, 2009, 05:26:08 AM
HI... just wanted to know can I set the CV disance to 1 instead of 180 ?
Yes, you can even set it to a decimal value like 0.3 if you like. You probably should set it to a value like 0.05 or something like that if your units is inch and you don't want it to "cut" your corners to much.
