Mach Discussion => General Mach Discussion => Topic started by: jdmaya on May 22, 2009, 08:02:36 AM
Title: User Button
Post by: jdmaya on May 22, 2009, 08:02:36 AM
How can I activate a user button with an external signal.
thanks.
Title: Re: User Button
Post by: ger21 on May 22, 2009, 08:21:50 AM
Set up an OEM Trigger in Ports and Pins>Inputs. The Hotkey for the screen button must match in the Screenset file and the OEM TRigger.
Post by: Hood on May 22, 2009, 08:29:37 AM
If its a VB button then I think you will be best to get MachMad plugin, it makes things like that easy.
