Mach Discussion => General Mach Discussion => Topic started by: Saumur on May 21, 2009, 09:01:22 AM
Good day,
I'm writing because I would like to know if it is possible to create a wizard program that suits the work I have to do.
Basically I have to grind a roll shaped item. The only thing that would change are the depth of the mark grinded and the space between the marks.
It's a simple program and I would like to know if it is possible to create a wizard to do it, and if so how.
Thanks for your attention
If you are good at VB then it should be easy enough for you to do a wizard. You can make a screen for the wizard with Screen4 or the new screen designer that Klaus has just done.
The Mach2 customization manual explains how to write a wizard.
http://www.machsupport.com/docs/Mach2_6.11_Custom.pdf
Thanks for ur answers,
anyway i know nothing about wizard and I'm not goin to make 1.
however I saw on mach3mill that there are many wizard and just wanted to know if there is one where you input these 2 values and the it creates the code.
The value to input would be the depth of the mark I have to do and how many marks I have to do.
The program done would do the following: grind a mark of 1 mm in my circual item, the motor moves a tot. of degrees based on how many marks i have to do and the grind another mark of 1mm and so on.
It's really easy the concept and I would really appreciate if you could tell me if a wizard like this has been made.
Thanks for reading
Thanks for reading
Not as far as I know.
YES it is called the gear/spline wizard. Tell it how many divisions and how deep to cutt and how far to move. It will generate the code
Thanks forhe help
