Mach Discussion => General Mach Discussion => Topic started by: freshwatermodels on May 14, 2009, 09:10:09 AM
I recently built a router using a mechatronics drive, 4 - 269oz steppers and Mach3. I had problems with the X/A slave axis but I got it running. I moved controller box to the computer stand and am again having problems with the X/A axis. I am getting a condition abnormal that reads "one or more axis disabled or enabled". I have double checked the configuration and played with the motor tuning but no success. Y and Z axis run very nicely. Just the X w/A slave being a problem.
I assume this is a Mach3 configuration issue. What am I doing wrong. Assistance appreciated.
Jack
What exactly is the problem?
Have you got the motors enabled in Cofig menu the Ports and Pins then Motor Outputs?
Do you have the axis slaved, Config menu then SlaveAxis?
Are the slave settings correct on Config then General Config page?
Hood,
Thanks for your reply.
X axis seems to respond to jog. Y seems to not respond or is hit and miss with gantry racking.
Ports and pins include X Y Z and A axes
Motor tuning seems OK
Slave configuration is X with A slaved to it.
Don't see anything on the Gen config page relating to slave???
Jack Mc Kie
Was meaning the A Axis settings on General config, not sure how they would affect things when using a slaved axis but if the A is set as angular it could well cause problems.
Please attach your xml and I will have a look and see if I can find a problem, I have never had a slaved axis so might not see anything unless its obvious though.
Hood,
Please excuse my ignorance. I searched for XML files in Mach3 and found backups in the form of .XB ie. mach3mill.xb204 Is this what you want?
Jack
You will find it in the main Mach3 folder, it will be called Mach3Mill.xml if you are using the default mill profile. You will need to copy it to a different location on your drive then rename it before the forum will accept it, suggest you call it freshwatermodels.xml
Hood,
Thanks! Here is the XML.
Jack
Ok on General config page uncheck that A axis is rotational and see if that helps.
No change.
Jack
Afraid the only other thing I see wrong is you dont have Home Slave with Master checked, then again as I said I have never had a slaved axis so not exactly sure what should be set up.
Having said that it sounds like it may be a hardware issue, check all the connections to the drive and breakout are good.
Also I am presuming in your first reply you were meaning the A axis when you said "Y seems to not respond or is hit and miss with gantry racking."
If it is a hardware issue then why do I get the warning light "one or more axis disabled or enabled" ? It would be nice to know precisely what the warning refers to and how to correct the abnormal condition.
I am going to try a Gecko G540 and see if there is any difference. I've never installed the G540 so this may take a while.
Thanks for your effort!!! It is appreciated!
Jack
The strange thing is I dont get that abnormal condition when I load your xml, I get one about the active plane.
When it works Mach3 is a pleasure to use but it has caused me more problems than any other software I use. I'm at a loss as to how to proceed. I'm workng on the Gecko drives to see if the problem is in the drivers but I think the real problem is in the software.
Jack
