Mach Discussion => General Mach Discussion => Topic started by: bbrown2005 on May 13, 2009, 07:47:09 PM
hi, i was wondering how do you set the width of the kerf cut is there a setting for that or do i have to compensate for that each cut
hi, what i do create an offset in cad . i use turbocad pro 10. my kerf is about .07. after i have drawn my part , i jion polyline, then offset .035, delete the original, and save.convert with lazycam .
thanks i did not want to sound stupid for asking but that works great because i have turbo cad v10 also thanks
another tip. make sure you save as a r12 dxf.i find that if you save as a r14 dxf,and there are arcs, lazycam will insert a m3 at an arc in the middle of a cut.a real annoyance to have happen.you can get rid of the arcs by exploding three times and then joining polyline, but if the arc is a large radius, will be faceted.
thanks. i am new with the mach plasma i have been working on my table for about 2 years and excited to have it going thanks, ben
