Mach Discussion => General Mach Discussion => Topic started by: dgoddard on May 11, 2009, 04:57:58 PM
Title: Mach3 Lathe Wizards
Post by: dgoddard on May 11, 2009, 04:57:58 PM
Just completed my CNC conversion for the Grizzly G0602 lathe and now am starting the learning and fun phase.  I plan to run in the Diameter mode.  My question is:  Do the "Lathe Turning Wizards" by Brian/Kiran output g-code in diameter or radius mode?
Title: Re: Mach3 Lathe Wizards
Post by: Hood on May 11, 2009, 05:13:12 PM
I run Dia mode and the wizards work fine :0
Post by: dgoddard on May 12, 2009, 05:35:13 PM
Tried a wizard out today and alll worked fine in diameter mode.
Post by: Hood on May 12, 2009, 05:38:34 PM
I think the VB in the wizards will actually look to see which mode you are in and output accordingly :)
