Mach Discussion => General Mach Discussion => Topic started by: ynneb on August 06, 2006, 01:41:41 AM
Title: Improved tool path display ( see video)
Post by: ynneb on August 06, 2006, 01:41:41 AM
http://www.machsupport.com/toolpath.wmv
Title: Re: Improved tool path display ( see video)
Post by: rceebuilder on August 06, 2006, 06:30:23 AM
I like it  . but is it possible to enlarge the toolpath display  , let's say full screen ?
Post by: ynneb on August 06, 2006, 07:57:47 AM
Yes the screen designer will allow you to create a full screen display if you want.
Post by: zealous on August 06, 2006, 04:46:41 PM
Great screen, I'm using it now and it adds allot to the machine experience.
Thank you ;D
One quick questions and one problem:
Is it possible to add a diffrent color to the toolpath when there is multiple pass. I sometimes find my self coming back to the machine an hour later not sure which pass it's on. Not a big deal.
I have been using the new screen all of today, and loaded many diffrent toolpaths, but for some reason one of my G-code files is not refreshing in the new screen. When loading the attached g-code file and rotating the view in the screen gives me ghosting and freezes up Mach.
I have test the same file on two diffrent computers with  Mach3 Dev. Version 1.90.051 and the file work fine.
I have tested the file on two diffrent computers with Mach3 Dev. Version 1.90.071  and both have the same problem.
Can any one verify this and give me a hint at what I'm doing wronge. See attachment
-Thanks
Post by: Chip on August 06, 2006, 05:58:57 PM
Hi, zealouse
There is a bug in .071 Art seed he found the problem and it will be fixed in next Release.
Chip
Post by: zealous on August 06, 2006, 06:05:39 PM
Thanks for the quick responce, I'll wait. The new features are great ;D
Post by: Brian Barker on August 06, 2006, 06:26:55 PM
This new 4th axis toolpath was a TON of work from Art and I... Art and I both didn't know if we could make Mach3 do what we wanted it to do... But as you can see we did it! Art is getting to be a very good OpenGL programmer! I only play the small part of making math do what he needs...  Art is truly a great programmer!
Post by: zealous on August 28, 2006, 06:53:18 PM
Just wanted to comment on how great the new toolpath screen is. ;D
The updated Mach is working great with no problems at all.
The new features and clarity are great.
If I can help with anything let me know.
