Mach Discussion => FAQs => Topic started by: Jens H on April 22, 2009, 07:06:27 AM
Title: Feed rate on start up.
Post by: Jens H on April 22, 2009, 07:06:27 AM
When I start mach3 the Feed rate is 6 (6mm/min--very slooow)
When i JOG this feed rate is used. I can change it, but next time i start Mach3 it is 6 again. Where can I change this value so it's default?
Title: Re: Feed rate on start up.
Post by: Greolt on April 22, 2009, 08:46:30 AM
Put it in the initialisation string in general config
F1000 for example.
Greg
Post by: Jens H on April 23, 2009, 01:58:28 AM
Thanks. That do the trick.
