Mach Discussion => General Mach Discussion => Topic started by: Psad on August 05, 2006, 08:31:42 PM
How does the "GO TO" button on the "Program Run" screen work.
I appears that it changes the coordinate system referenced to the tooling position.
Is that true.
Go To Button?? Are you talking about the Go To Z Button? Which version of Mach3 are you runing?
Sid
It tells you the Distance to Go for that block... When the DRO's read 0,0,0 the move is done...
