Mach Discussion => General Mach Discussion => Topic started by: Cartierusm on April 18, 2009, 07:58:45 PM
I am installing my VFD for spindle control and I'm using the C6 board from CNC4PC and it says in motor tuning under spindle to change the step pulse to 3. Well this changes the step pulses on my X Y and Z axis from 0 to 3 as well, what will this do to the other axis'. Thanks.
It shouldnt do any harm.
Thanks, what does the step pulse do?
It basically changes the duration of the pulse ....higher #, longer pulse.
RC
So how does going from zero to 3 not affect the motors, or is it just a slight delay in the way the pulses get there? I guess it's better to have them slightly longer than too short where the motor can miss a pulse?
Picture a 12" ruler with 1 pulse per inch.
The pulses could be 1/8" wide, or 1/2" wide.
Same amount of pulses per foot, just wider pulses with less gap in between.
Some electronics and isolated BoB's and such need the longer pulse so it is seen through the system
RC
Ok, thanks for the explanation, just making sure it won't change anything and make the steppers act funny or mis steps.
Like HOOD said......it shouldn't, and I'll add.....most likely wont.
It will depend greatly on your overall set-up.
Time will tell.
RC
LOL, that doesn't sound to reassuring. What should I be looking for?
What drives do you have?
It's a Bridgeport Clone with Ballscrews. 3x 1200 oz/in. Keling Steppers, 8078 Keling Drives, 72VDC 20A Keling PS.
Keling drives really need 2 or 3 on the pulse width anyway, or at least the ones I have on the coill winder do, they are not actually keling named but exactly the same.
I use the same exact components on my CNC router, I use quick disconnet plugs to save money as I never run both machines at once. I'll look into that, but I've never had a problem on the router, but then again I'm not sure I'd know what to look for. Thanks for the help.
Motors just sounded sweeter with mine set to 2 or 3 on the coilwinder.
