Mach Discussion => General Mach Discussion => Topic started by: deepakjankie on April 08, 2009, 01:19:57 PM
Title: problem drill circular bold pattern. Brain Barker
Post by: deepakjankie on April 08, 2009, 01:19:57 PM
can some one help me.
i'm just a beginner , i started mach3 mill . opened the wizard and i went to brain barker circular bold pattern wizard.
i filled all the fields but wen i press on the button to post the code i get "l error on line: 27 , mismatch
can some one tell me wat i am doing wrong here?
Title: Re: problem drill circular bold pattern. Brain Barker
Post by: Hood on April 08, 2009, 01:31:18 PM
can you attach a screenshot showing the settings you are entering ?
Post by: deepakjankie on April 08, 2009, 05:02:54 PM
thnx for helping
Post by: Hood on April 08, 2009, 05:10:01 PM
All looks fine if rather large LOL. tried it here with your numbers and its working, maybe a corrupt wizard, try downloading Mach again and installing over the top of itself.
Post by: deepakjankie on April 08, 2009, 05:19:21 PM
i have the problem on 2 computers.
could it be my tool settings. because i have no tools attached. or some other settings
Post by: Hood on April 08, 2009, 05:23:16 PM
If you installed from the same download it could be corrupt, if different then its unlikely.
If you want to attch your xml I can have a look, you will find it in your Mach3 folder, if you are using the standard profile it will be called Mach3Mill.xml
You will need to copy it to your desktop then rename for the forum to accept it, suggest you call it deepakjankie.xml.
Post by: deepakjankie on April 08, 2009, 05:41:19 PM
xml attached
Post by: Hood on April 08, 2009, 05:58:47 PM
Works fine here with your xml so must be a corrupt file in your download I think.
 Try unzipping the attached file to C:\Mach3\Addons and see if that helps.
Post by: deepakjankie on April 09, 2009, 04:05:47 PM
i still have the problem sir. wat can i try now sir?
Post by: Overloaded on April 09, 2009, 04:26:17 PM
I notice in the pic of the settings, the units are INCH, the BC dia is 150" and the depth is 15".
Huge machine.....or could be a problem ?
RC
Post by: Hood on April 09, 2009, 04:31:52 PM
What version of Mach do you have?
Post by: deepakjankie on April 12, 2009, 05:11:38 PM
i have only 1    3flute(2mm ) to cut carbonsteel  rpm 6000  does someone know at wat  speed i can set it to run in mach3
how many units /minute?
