Mach Discussion => General Mach Discussion => Topic started by: harun on April 05, 2009, 06:16:01 PM
Hello,
I am a nwe CNC user and using MAch3, Lazycam to create G codes.
I have a problem arranging the offsets.
Let's say I need a rectangle cut of 10mm X 20 mm and I use a 1 mm fraise. How can I arrange the tool to cut outside the line so that I can get a 10mmX20mm clean rectangle.
I tried to use LazyCam's offset options but it did not help.
Is there a way to make it in Mach3?
Thanks in advance.
Harun
Offset the lines in your CAD program before importing to LazyCAM.
