Mach Discussion => General Mach Discussion => Topic started by: Rodm1954 on March 31, 2009, 04:52:16 AM
Title: Homing and Slaved Axis
Post by: Rodm1954 on March 31, 2009, 04:52:16 AM
I am having problems homing my slaved X axis. I have set it up with A axis and changed A axis to linear.
I am using Refcombination(9) as the command to home.
Lockdown version R3.042.202
What happens is it homes the X axis as it should but no movement at all from A axis once X is homed. Also all the limits are disabled when this is done and I have to hit reset, then rest again to activate the limits. I have skewed the gantry to make sure A axis is not leading X to the limits and no difference.
Obviously I have checked and rechecked the settings but can't see the obvious yet.
I have attached my xml file and would really appreciate somebody helping me with this.
thanks,
Rod
Title: Re: Homing and Slaved Axis
Post by: Greolt on March 31, 2009, 06:08:52 AM
Sent you an email Rod
Greg
Post by: dgalaxy on April 16, 2009, 09:22:19 AM
i am haveing the same problem could somebody tell me what the fix was
John
Post by: Rodm1954 on April 16, 2009, 10:11:41 AM
Greg was very helpful running through various combinations and looking at my xml file but it was never resolved.
I put it down to a bug in Mach3 but are in hope it will be fixed.
Let me know if you find a fix.
Post by: Greolt on April 16, 2009, 05:48:53 PM
Slaved axis homing works.  Lots of Mach users have it working fine.
Tell us what your problem is John.
Greg
