Mach Discussion => General Mach Discussion => Topic started by: keeman00 on March 30, 2009, 07:33:24 AM
Title: Need help
Post by: keeman00 on March 30, 2009, 07:33:24 AM
HI I am new in cnc machines and i have problem to config my cutting speed when i load some file for example 1 line which is long 1 meter mach3 cut this for 1 min.My question is how to cut the same line for 10 sec .What I have to change.
Title: Re: Need help
Post by: Graham Waterworth on March 30, 2009, 12:19:25 PM
The F command controls the feed rate of the axis, if you are working in metres then the feed you have is F1000. to move 1 metre per minute,  to make it move 1 metre in 10 seconds then you have to move 6 times faster so F6000. will do this.
Graham
Post by: keeman00 on March 31, 2009, 09:53:14 AM
Thank you I tried and works Actually before to load file in mach3 i can adjust my feed rate in lazycam I think .
But thank you for the fast answer.
I need that because I'm building plasma table (X=1m y=2m) I will  cut about 1 mm steel  thats I need fast cutting speed.If you can somebody can give me some tips I will be happy to learn.
