Support => Downloads => MACH TOOL BOX => Topic started by: vmax549 on March 28, 2009, 09:27:13 PM
Title: Macro, Drilling, Bolt circle with MANUAL quill and spindle
Post by: vmax549 on March 28, 2009, 09:27:13 PM
Here is a macro to drill Bolt circles using a MANUAL quill and spindle. It will hold at each drill point and let you drill the hole then hit OK and it will move to the next location  and so on.
To use Move to the CENTER POINT of the bolt circle and call the macro and program the Arguments
NOTE: We are using Macro arguments directly into the macro with the PQR (;-)
IE: M2224 P4 Q0 R4      ( moves to 4 locations starting at 3 oclock at a 4" radius from the centerpoint stops anmd waits for you to drill then you click on OK to continue)
Argument assignments
P= Number of Holes
Q= Starting angle (0=3 oclock)
R= Radius of Bolt CIrcle
CODE EXAMPLE:
'Macro M2224  Bolt circle Drill Manual Quill/SPindle
Sub main
Dim P101 As Integer
Dim P11 As Integer
' M2224 Pxx Qxx Rxx
' R = Radius of Bolt Circle
' Q = Starting Angle (0= 3oclock -- Neg = CW)
' P = Number of HOLES
SetVAR(24,Getdro(1))
Setvar(25,Getdro(2))
Setvar(11, Param1())
SetVar(1, Param2())
SetVar(18, Param3())
Code" #101=0 (Initialize counter)"
Code" #102=#1 (Initialize current angle To A)"
Code" #103=[360 / #11] (Constant For incremental angular distance between holes)"
Code" G0 Z#104 X#24 Y#25"
N1:
Code" #110=[#24 + COS[#102] * #18] (Calculate X position for current hole based on current angle)"
Code" #111=[#25 + SIN[#102] * #18] (Calculate Y position for current hole based on current angle)"
Code" G0 X#110 Y#111 (Machine current hole)"
MsgBox "Drill HOLE    " &" Then Press OK to continue"
Code" #101=[#101 + 1] (Step counter)"
Code" #102=[#102 + #103] (Step current angle)"
P101= GetVAR(101)
P11= GetVAR(11)
While Ismoving()
Wend
If P101 <= (P11-1) Then GoTo n1 Else GoTo N99
N99:
Code "M30"
End Sub
Title: Re: Macro, Drilling, Bolt circle with MANUAL quill and spindle
Post by: Overloaded on March 28, 2009, 10:20:15 PM
Now THAT is just slicker n' snot on a doorknob.
Just ran it in simulation...If I had Z set up on the knee I'd be using the heck out of this.
Thanks Mr. Parker,
RC
Post by: vmax549 on March 29, 2009, 01:49:51 PM
RC I work for a living like everyone else( not a MR or a SIR)
 MOST just call me TP(;-)
Post by: Overloaded on March 29, 2009, 02:07:44 PM
Thanks TP......keep up the good work.
RC
Post by: Greolt on March 29, 2009, 05:21:19 PM
I have edited this post so as not to clutter up TP's excellent thread.
This is my attempt to alter TP's code to have it ask for the parameters.
I have blatantly used TP's other threads as a guide.
The good parts are all TP's.  The not so good bits are mine.  ;D ;D
This is simply a learning exercise for me.
Thanks again for your efforts TP.
Sub main
Dim P101 As Integer
Dim P11 As Integer
Begin Dialog DiaLogName1 60,60,80,150, "Drill Circle"
TEXT 10,10,100,10, " Number of Holes"
TEXT 10,40,100,10, "Bolt Circle Radius"
TEXT 19,70,100,10, "Start Angle"
TEXT 18,82,100,10, "0 = 3 oclock"
TEXT 15,94,100,10, "CCW   0 - 360"
TEXTBOX 20,22,35,10, .Nholes
TEXTBOX 20,52,35,10, .RadBC
TEXTBOX 20,106,35,10, .Sangle
OKBUTTON 20,130,35,12
End Dialog
Dim Dlg1 As DialogName1
Dialog Dlg1
Setvar(11, Dlg1.Nholes)
SetVar(1, Dlg1.Sangle)
SetVar(18, Dlg1.RadBC)
N1:
P101= GetVAR(101)
P11= GetVAR(11)
While Ismoving()
Wend
N99:
Code "M30"
End Sub
Post by: Greolt on March 29, 2009, 05:33:02 PM
I see TP has posted an example of how to do it with a single text box on the other bolt hole circle thread.
I have edited the above post so as not to clutter this thread.
Greg
PS:  How do I have it enter a default value for a text box?  EG, zero for angle.
Post by: TDAY on July 31, 2009, 11:34:47 AM
Hello all,
Just found out about this toolbax and the use of these macros.
I put the edited code into a button and this is VERY nice!
Was wondering if there is a way to maybe...."edit" this macro and others, and have it post a Gcode somewhere?
Or maybe a way to save what you entered before. So when you push the macro button and window pops up, everything you entered before would be there.
Thanks again TP for telling me about this. :)
Troy
Post by: vmax549 on July 31, 2009, 10:14:10 PM
Troy the beuaty of Macros are they do not need to generate a separate Gcode file THEY are the gcode files with vars to define the function changes needed.
Yes you can store the variables MACH HAS A SECTION OF var #500-600 THAT ARE PERSISTANT and will stay put after mach shuts down. So it is possible.
AS to your idea, (;-)  Yes it can be done. Can you explain how you would use it?
Post by: TDAY on August 11, 2009, 06:54:01 AM
Sorry, for just now responding but i didnt receive a email notifier,got it set to do it.
Anyhow,the reason to generate and store a Gcode, so if i have a small production run i dont have to re-enter the macro for every part.
Troy
Post by: darlly01 on September 11, 2012, 02:03:04 PM
Hi to all,
this forum has a lot of experts. I'm new and getting all information to keep going with my projects. I need a help to do a Macro.
I found a macro to run a Powerpoint slides. It is working fine. It execute the slide show perfectly.
This is what I want to do: Computer showing the slides and when cylcle start button is pressed the slide show stop and the gcode is executed, when finish the gcode it start the slide show again. Please any help will be very great. thanks
