Mach Discussion => General Mach Discussion => Topic started by: tubular2000 on March 15, 2009, 12:35:28 PM
hi,
i try to install a joystick on my lathe. i use mach 3 3.042.020 under xp with directx 9. i tried using the joystick plugin that instaled with mach3, nothing moving. i tried dowloading the available plugin in the dowload area, no moving. then i tried using keygrabber, but it seems that it is not working properly. when i try to set it up, i cannot stop it. it is always grabbing even when clicking stop grabbing. i can see my joystick is there and available, i can set up the buttons, but when i switch to the joystick tab, it is scanning the axis at high speed so i cannot set it up properly. then when i click open mach3, it opens up but nothing working. when in keygrabber, if i it the testing menu a small window opens and it freeze. i downloaded a new copy of keygrabber(4.0.0.11) and replaced in the mach folder with the same result.
any advise?
i connected a logiteck attack 3 and the keygrabber seems to work properly, but still nothing in mach 3. the joystick that i would like to use is a megatron oem usb. but it doens't seem to work properly with keygrabber. anyone out there using an industrial joystick with good results?
This may help some.
http://www.machsupport.com/forum/index.php/topic,1391.0.html
