Mach Discussion => General Mach Discussion => Topic started by: Greolt on March 09, 2009, 03:43:56 AM
Title: Pause/Feedhold LED broken again?
Post by: Greolt on March 09, 2009, 03:43:56 AM
In November (3.042.018) we got the pause/feedhold LED fixed after such a long
time.
In January (3.042.021) it appears it might be broken again.
Greg
Title: Re: Pause/Feedhold LED broken again?
Post by: ger21 on March 09, 2009, 08:01:37 AM
I tried it recently and it didn't work for me either.
Post by: Chaoticone on March 09, 2009, 02:47:00 PM
Greg, are you talking about OEM LED 805? I'm testing and trying to help verify. Are you setting the led up as system function "Pause" or useing an oem code?
Post by: Greolt on March 09, 2009, 04:05:59 PM
System function "pause"
OEM LED  80  "Pause Active LED"
OEM LED  805   "Pause LED"
OEM LED  111  "Feedhold when part of a block executed - remainder pending LED"
None of these will work for me with Ver  3.042.021
The other thing is that the "Run" LED does not go out when in feedhold either.
As far as I know all the above worked in Ver  3.042.020
Greg
Post by: Greolt on March 09, 2009, 04:30:05 PM
Reinstalled Ver 3.042.020 and all work as expected except for OEM LED 80
So despite that Brian says he tested it and it's working.  It is not working for me.  :)
Greg
Post by: Chaoticone on March 09, 2009, 04:53:22 PM
OK, thanks Greg
Post by: Chaoticone on March 09, 2009, 05:03:27 PM
Greg, I just tested an exe and it works a treat  :) . System function and all 3 leds.
Post by: Greolt on March 09, 2009, 05:49:57 PM
OK thanks Brett.
That just proves I am doing something silly.   :)
Just to confirm, you tested in  Ver 3.042.021
Maybe I will do a fresh download of that version and try again.
Greg
Post by: Chaoticone on March 09, 2009, 05:53:36 PM
No Greg, you were right. I have been testing a new, yet to be released exe and it is fixed up in it.
Post by: Greolt on March 09, 2009, 06:07:09 PM
Glad to know I am not loosing my marbles.  ;D
Re down loaded and installed Ver 3.042.021  and they don't work.
Guess I need to stay with the lockdown version.
Greg
Post by: Chaoticone on March 09, 2009, 06:09:38 PM
Jury is still out on this one Greg.  ;D
I'll post in this thread when the fixed version is ready for download.
Post by: Greolt on March 09, 2009, 06:15:05 PM
Not if you ask my missus.  It is a well and truly established fact.
Thanks Brett
Post by: Chaoticone on March 10, 2009, 03:21:12 PM
Greg, Mach3 R3.042.022 is ready for a test. Let me know if it fixes you up please. I hope to be back online in a few hours.
Post by: Greolt on March 10, 2009, 04:38:03 PM
OK got the latest release candidate.
In the office here it looks to work great.  Even better than previous versions.
OEMLED 80 now works.
80 and 111 come on immediately once feedhold is pressed.
Pause and 805 wait until movement has stopped.
I'm off to the shed to install and try it on a machine.
Thanks,  Greg
Post by: Chaoticone on March 10, 2009, 05:45:12 PM
 :) Thanks Greg.
Post by: Chip on March 10, 2009, 07:10:12 PM
Hi, Guy'es
Still see some issues hear,
Chip
Post by: Greolt on March 10, 2009, 07:22:34 PM
Sorry Chip I don't know what you are showing us.
I am not so familiar with the standard Mach screenset.
Greg
EDIT:  Here is a screen grab from my test screenset.
Post by: Chaoticone on March 10, 2009, 07:27:57 PM
Chip, I haven't seen this yet myself but I think the problem in the one pic with the top and bottom of the led are visible and the sides aren't is a graphics update issue. Not a biggie. If it is what I think chances of that getting looked at are slim to none. The way the buttons work is when you push them they get slightly smaller to give an illusion of physically pushing a button. I have noticed minor quirks with this in the past but there are bigger fish to fry if that is the problem. Try editing the set and make the button over the led slightly smaller and I think that will fix that problem. In the picture where there is no feed hold led or cycle start led I think you pushed the stop button.  ;D  No really, there are 4 LEDs associated with feed hold and depending on which you have selected, that combonation is possible. The feedhold LED coould light on press or when everything comes to a stand still depending on which led you have selected to use. The start will deactivate as soon as you hit feed hold.
Post by: Chip on March 10, 2009, 07:34:36 PM
Hi, Greg
Put them up without much detail to show Brett, Still looking at it now, There intermittent hear.
Thanks, Chip.
Post by: Greolt on March 10, 2009, 07:42:54 PM
No worries Chip
Leave you to it.  :)
Greg
