G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: bfairey on February 27, 2009, 02:20:00 PM
Please see attached code
Brian.
You have not succeeded in attaching the code Brian.
Thanks Tweaky but where do I attach the file?
Brian.
Hi Brian,
Click on 'Additional Options' then see 'Attach' use the 'Browse' to select the file (note only certain file types are allowed) then post.
Please see what you can make of this
Brian.
You need to attach the g-code, not the .dxf
Hi Brian,
I don't know if you are cutting the part or engraving/drawing it. Assuming the profile was to be engraved I have converted your dxf to GCode (using Vistool 6) and the file is attached for you to look at.
