Third party software and hardware support forums. => dspMC/IP Motion Controller => Topic started by: halkintool on February 09, 2009, 10:26:01 AM
Title: Analog inputs.
Post by: halkintool on February 09, 2009, 10:26:01 AM
My dspMC is capable of 8 Channels Analog Inputs, Range 0..5Volts, 14-bit Resolution. Im curious as to how i would utilize this through Mach3.
It would be ideal for me to be able to utilize some of these inputs in my macros, just wondering if its even possible?
Title: Re: Analog inputs.
Post by: Vital System Support on February 09, 2009, 10:30:55 AM
the analog input data is stored in oem dros in mach.  what hardware model do you have 7761 or 7761-Sx or 7761-Mx.
Post by: halkintool on February 09, 2009, 10:40:02 AM
7761S, how do you access oem dros? can you assign a port/pin(input number) to the analog signal?
Post by: Vital System Support on February 09, 2009, 10:53:21 AM
sorry, the analog inputs are only available in 7761-M.  pls see the webpage www.vitalsystem.com/dspmc
Mach OEM DROs 1320..1327 are reserved for analog inputs.  plugin should be v1.9 or later.
Post by: halkintool on February 09, 2009, 11:33:31 AM
Gotcha. Ill have to do a little work around :)
