Third party software and hardware support forums. => Modbus => Topic started by: Cncman2nv on February 02, 2009, 06:17:01 PM
I have a ModIO board with a Mpg wheel hooked up how do i get the mpg wheel to move an axis in step mode .100/.010/.001 incerments
I use the flayout jog screen jog mode set to MPG cant get single step to work
Hi Adam,
I have a feeling that single step mode does not work in Mach3. You need to use MultiStep.
Best to check with Brian.
Cheers,
Peter.
I am starting to wonder if i have a bad MPG wheel this my first one it pulse out 4 to one click and even in multi step moves the axis to the
set interment once then thats it if i spin the wheel fast it moves the dro but i dont know when it will stop
In Hi Res mode the ModIO counts every transition, so there are 4 per click. Have you tuned the MPG under the config tab?
In Multistep mode Mach remembers how many clicks you have moved and will mode the axis to the distance represented by the number of clicks.
Cheers,
Peter.
