G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: k.kuramochi on February 02, 2009, 02:32:13 PM
Title: japanese font can't be used
Post by: k.kuramochi on February 02, 2009, 02:32:13 PM
I'd like to use Japanese font on LazyCam.
I can see Japanese font name on font window when I select "TEXT" tab.
But Japanese charactor can't be dragged.
Could you tell me how to do.
Title: Re: japanese font can't be used
Post by: budman68 on February 02, 2009, 02:35:53 PM
Possibly you could use the font in your CAD program and save as a 11/12 ASCII dxf and import that into LazyCam?
Post by: k.kuramochi on February 04, 2009, 04:33:21 PM
What is a 11/12 ASCII dxf? Is ther any difference between a 11/12 ASCII dxf and just dxf?
I tried to import dxf file which I made by visio. But I couldn't see any charactors on LazyCam.
Post by: budman68 on February 04, 2009, 04:53:59 PM
It's just a type of dxf that seems to be the best for LazyCam.
As for just a "regular" dxf, I'm sure it's a certain type that you're using, it just doesn't specify which type.
Post by: Chip on February 04, 2009, 08:43:15 PM
Hi, k.kuramochi
Post your dxf file so we can look at it.
Do you have the Ignore "Text Entities" box un-checked in Setup, Loading Options in LazyCam.
Chip
Post by: Chip on February 05, 2009, 03:40:55 AM
Hi, k.kuramochi
Got your dxf, Several issues, The file name isn't recognized, I renamed it ttest.dxf, It's standard dxf AC1014 format but your Japanese Font is not recognized by LazyCam, Only 2 of my cad programs would even see it as Font's, See below.
There is a Autodesk/Autocad utility that may convert the format for you.
http://teknigroup.com/support/ACAD/kanji2007.html
Direct to the 2 files you may need:  http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8109007&linkID=9240618
Hope this Helps, Chip
Post by: Chip on February 05, 2009, 03:07:27 PM
Hi, k.kuramochi
Hears the original dxf, Whin I uploaded it the font letters changed to numbers.
Chip
