Mach Discussion => General Mach Discussion => Topic started by: axilleas on July 21, 2006, 05:11:13 AM
Hello
I am using a script for a M function with G4 Pxx (wait xx seconds).Thats fine
Then I want by pressing a button to stop waiting and continue executing next line.
Any help?
Thanx
It's me again
Accidentally I found that the button I asked above is the "Run" button. :)
BUT
I created a new vb script button with dobutton (0) and some other lines. When I press the green play button in the script editor it works fine (NOT step by step). When I close the editor and press the button it is not the same!! (feedrate gets equal to x position, the movement is not the next line.... ???)
Thanx
Why can't you use an M0 (Mzero) instead of a G4 Pxx, M0 will wait until you press the start button.
Graham.
There is a userDRO with the time xx (G4 Pxx) given by the user. This is the preheat time of an oxy flame.
Usually the user set this userDRO before start cutting without knowing if this time is ok. Usually he sets a high number. During preheat user can see the flame and push a button when he thinks that the time is ok. The time from the start of the preheat is recorded in this userDRO so next time preheat will be ok.
So M0 is not an option.
Thanx
Here is the button script
c=Timer()
totaltime=(c-getuserdro(1002))
setuserdro(1000,totaltime)
dooembutton(1000)
1002 userDRO is the time from the beginning of the preheat. I use M18 to fill 1002 up.
b=Timer()
setuserdro(1002,b)
preheat=getuserdro(1000)
ActivateSignal(Output4)
code ("G4 P" & preheat)
totaltime is the the xx (G4 Pxx) time
dooembutton(1000)=dobutton(0) I think. I tried them both.
As I have described when I use the normal Run button it stops waiting and continue with next line. When I use this button the calculations in the first 3 lines are done correctly but then the feedrate gets equal to Xposition and it moves to a no sense place. When it reaches that place it continues as if it has done next line.
Appart from the fact that if I have open the script editor and I "play" the script from within the editor, it works fine, it works fine the for the second or third curve.
For example:
N0000 (Filename: Drawing1.tap)
N0010 (Post processor: Copy of Mach2.post)
N0020 (Date: 24/7/2006)
N0030 G21 (Units: Metric)
N0040 G40 G90
N0050 F1
N0060 (Part: Drawing1)
N0070 (Process: No offset 0, Mill/Router, 0,1 mm diameter, 0 mm Deep)
N0080 M6 T0 (Mill/Router, 0,1 mm diameter)
N0090 G43 H0
N0100 G00
N0110 M04
N0120 X180.3516 Y119.7404
N0130 (Part: Drawing1 Duplicate 1)
N0140 M18
N0150 G02 X180.3516 Y119.7404 I-67.4337 J0.0000 F3000.0
N0160 (Process: No offset 0, Mill/Router, 0,1 mm diameter, 0 mm Deep)
N0170 M17
N0180 G00 X170.1790 Y266.9916
N0190 (Part: Drawing1 Duplicate 2)
N0200 M18
N0210 G02 X170.1790 Y266.9916 I-67.4337 J0.0000
N0220 (Process: No offset 0, Mill/Router, 0,1 mm diameter, 0 mm Deep)
N0230 M17
N0240 G00 X306.6313 Y199.9025
N0250 (Part: Drawing1 Duplicate 3)
N0260 M18
N0270 G02 X306.6313 Y199.9025 I-67.4337 J0.0000
N0280 (Process: No offset 0, Mill/Router, 0,1 mm diameter, 0 mm Deep)
N0290 M17
N0300 G00 X388.5027 Y82.7810
N0310 M18
N0320 G02 X388.5027 Y82.7810 I-67.4337 J0.0000
N0330 M05
N0340 G00
N0350 G00 X0 Y0
N0360 G49
N0370 M05 M30
If I push the button while waiting in N0140 >:(
If I push it during N0200, N0260 or N0310 it works well ???
Thanx
I also found out the "no sense" movement. In G is
G01 X119.7404 Y112.9179 F180.3516
which is not so much "no sense".
Normal line is
Y gets X
I gets Y (180.3516-67.4337=119.7404)
and X get F
I though that while N0150 is the first "cutting" line a problem occurs. So I put a G01 F3000 in the beginning but it did not work.
I am very sorry for bothering you so much
Thanx
It is exactly what is being discussed here
http://groups.yahoo.com/group/mach1mach2cnc/message/25060
Thanx
Hello,
You are looking to change the dwell time... Hmmmm I think the best way to change to dwell time with a DRO is to use the M3 and M5 macros :) Much the same way that you have done here:
c=Timer()
dooembutton(1000)
b=Timer()
setuserdro(1002,b)
I don' t get what it is that you are trying to do :( If it was e and I needed to change the Pre heat time I woudl do the following
'M3
DoSpinCW()
and to turn off
'M5
DoSpinStop()
Sorry i don't see what you need :(
the other thing that you are talking about :
"I also found out the "no sense" movement. In G is
G01 X119.7404 Y112.9179 F180.3516"
What is a "No Sense" Move??? are you talking about a nonprobe move?
we will get you fixed up
Brian
Sorry for not making myself clear. :-[
I use a DRO with dwell time. Instead of M3 I use M18. I do exactly what you said and it is ok.
Your M3 is
DoSpinCW()
My M18 is
b=Timer()
setuserdro(1002,b)
The only difference in that you use DoSpinCW() and I use ActivateSignal(Output4). I also use userDRO 1002 as a public var to store the exact time that preheat was started. I want this time because I have a button with the following script.
c=Timer()
dooembutton(1000)
When the user presses THE button during waiting time (dwell) I calculate the "totaltime" var which is the time from the beginning of the preheat and the time THE button is pressed. Then I store this time to the userDRO 1000. This time will be used the next time from M18.
ALL these works fine.
The problem I have is with the DoButton(0) and the equivalent DoOEMButton(1000).
During dwell (G4 Psomething) time you can cancel waiting by pressing the Run button. I put dooembutton(1000) in my button so after the calculation of totaltime the movement to be start. This also works well in all occasions except form one. I have to explain it to you with a small example
N01 G00 X100 Y100
N02 M18
N03 G01 X250 Y200 F3000
N04 M17
N05 G00 X200 Y100
N06 M18
N07 G01 X350 Y200
N08 M17
N09 ....
I have the script editor open with the script of THE button. I press the green play button inside the editor during dwell time in line N02 and it work fine.
I also press it during N06 line and it also works fine. Now I close the editor window.
If I press THE button during N02 "totaltime" calculations are done well but the movement is not G01 X250 Y200 F3000 it is G01 X200 Y0 F250. :o (Feedrate is the X, X is Y and Y is 0)
If I press the button during N06 then everything is OK. It is OK even if I had already pressed THE button once in N02 or for the first time.
I am again very sorry for not making myself clear. Maybe is my English. It is not my mother language.
Bye from Greece
Thanx
You did well !
Try to use DoOEMButton(288) To cancel the Dwell. This should work :)
Best of luck
Brian
hi guys
how would i get contact with the user name axilleas he talk about dwell features that i realy need and would like but i need more help i am new to mach 3 Thank you ley me know
just pm me :)
Hi axilleas
I am Mark I am new to a mack licence user on the dwell post you guys talk what i want on my cnc machine I use a flam cutter and plan to add on a plasma but a the dwell feature i want z axis to plunge down preheat until i comment the machine to start the torch and start moving the x y axis on the toolpath i know it can be done because you guys talk about it in the forums so Please let me know how to do it it would be greatly appreciate
Simplest way would be to put M1 in the code where you want it to stop, when its ready to move again all you do is press start, If you knew the exact time you wanted a pause you could put G4 P** (** being time in seconds) and after that time had elapsed it would continue.
would i have to add M1 Manuel on every plunge If that is so there has to be a better way
Ho many plunges/pauses would you be looking at in a typical programme?
How do you write the programme, if its with CAM it may be possible to get the CAM to add it automatically.
on a flamcutting a guy dose quiet a bit of plunging as far as the cam i plan to use lazycam i appreciate our feedback Thank you
not sure if it would be possible or even practical but you may be able to use the macro pump. Adding a bit of code to pause or M1 when a given situation is seen shouldnt be that hard to do. I am fairly new to VB so maybe I am just talking through my arse.
I would not mined if i had to push the start buttom on every plunge
If you will be present each time you plunge could you not then just press the feedhold button then when you want to go again you could press start?
That is the problem you always have to be there and just after the plunge it start to cut then you have to reverse the program
Yes that is true.
Been trying with the macropump and I cant get it to work :( as I said I am new to VB so it may still be possible. In the mean time it wouldnt take long to edit your code, even if you have 50 plunge moves all you would need to do is open your code in notepad, press Ctrl + F, type in the plunge move (eg if the plunge is G0Z1, type that in) then hit find next. You can then enter a new line below such as M1 then press find next and so on, should only take a minute to do.
Sorry cant be much more help :(
Hi
Here is a E-mail which I sent Brian is how I think it can be done
I notice if I use
lazycam to create a G code on a part with the plasma options feature
the M3 commend turn on the plasma before the z axis does it's plunge
which i am sure work if a guy has a automatic torch height control but
if a guy uses without height control you want the torch to turn on
when the z axis is plunge the same way it work with a flame cutting
torch Here is what I thought Art. Could you add something in Lazycam
in the posting option / plasma options where a guy would add in a
command line before plunge and after plunge a guy could write in the
cod like M1 / Ms that way the machine waits for the start button then
if you push the start button then the torch would start if you had
them options for before plunge and after plunge it would work for
plasma with height or with out height control and with a flame cutting
torch my old software worked that way and on that part it worked
alright then it also could be used for dwell feature So let me know
what you think it sure would be nice
as always Thanks again for your understanding that you are working
with not so smart of a guy
Hello Mike,
There is a post processor in Lcam and you are just using the default one... I will write you a simple post file to fix your trouble
Brian
Here is a post for you to test. install it into the Mach3 directory and load the post in Lcam under the "post options"
Also if you would like to edit this more here is the Var list :)
Hi Brian
I am Mark not Mike but no big deal I tryed the post 2 problems 1 the G cod program file does not run this file in the status bar it reads Unclosed comment found on line number #1 Problem 2 nothing shows up in the toolpath screen Let me know
thank you Mark
This is a post for Lcam and you need to put it in the mach3 directory. after that you need to select the Post that you would like to use with the Select Post on the Post options dialog. after that you should have the M1's that you wanted in the programs from Lcam
This post processor is exactly what I was looking for to "manually" control my torch until I get THC. Thanks a bunch!!! I've been inserting M1's by hand which gets to be a pain on complicated drawings.
Hello everybody.
I'm facing the same problem with achilleas and the DoOEMButton(288) didnt solve the problem.
Any ideas?
