Mach Discussion => General Mach Discussion => Topic started by: mrmatt68 on July 20, 2006, 09:44:34 AM
Title: Feed Rate Display Problem in Mach 3 when slaving an axis
Post by: mrmatt68 on July 20, 2006, 09:44:34 AM
when setting IPM in motor tuning to 1000 IPM axis will run at 1000 IPM but when i slave the Y axis the display shows 1440 ipm and no actual speed increase on that axis.  Am I setting something wrong.  Occurs in lockdown release.  XYYZ machine configuration and the other axis seem to be fine.
Title: Re: Feed Rate Display Problem in Mach 3 when slaving an axis
Post by: mrmatt68 on July 20, 2006, 10:19:26 PM
the a-axis check box for angular is not checked either.......i don't know if this is just the way it works but seems like a bug to me.  Also I am running the rutex 2020 drives if that make a difference.  :)
Post by: mrmatt68 on July 22, 2006, 05:21:33 AM
hello
Post by: Brian Barker on July 22, 2006, 08:43:00 AM
I was thinking that we fixed that one... I will tell Art about that when he gets back
thank you
Brian
Post by: mrmatt68 on July 22, 2006, 09:13:16 AM
ok thank you
