Third party software and hardware support forums. => dspMC/IP Motion Controller => Topic started by: halkintool on January 13, 2009, 10:54:07 AM
When i execute a command with a graph, my results come up, i get a red line, a blue line and a green line.
However, where the text comes up on the left labelling the lines, all 3 layers of text are ontop of each other and i can't tell which position line is command and actual. Is there a newer version of axis works to correct this?
This is off the vital site and its obvious what color does what, but thought it could be looked at :)
(http://www.vitalsystem.com/web/motion/awgraph.JPG)
Just so you know what im talking about.
Velocity is also spelled wrong...
halkintool,
thanks for reporting this issue. will get it fixed in the next release.
regards,
Rufi
