Mach Discussion => General Mach Discussion => Topic started by: Robhi on January 01, 2009, 12:52:50 PM
Hi everybody,
happy new year to all of you.
I would like to know the function of disable in Gecko 201, Could I leave it alone and not connect it to any other wire?
What it is the advantage if I connect it (use it) and how could I use it?
thanks you and happy new year again.
Robhi :)
I know you dont need it as I never had it wired when I had G201's. I have G202's now with the same wiring but on them the disable pin says NC (No Contact I presume)
I would imagine the disable on the G201 would be so you could manually disable them from putting out any step pulses if you wished.
Hi Hood and all,
Thanks too much for your answer I appreciate that.
Robhi
