(1001) (T1 D=0.25 CR=0. - ZMIN=-0.0395 - FLAT END MILL) (T55 D=0.0625 CR=0. - ZMIN=-0.0001 - FLAT END MILL) m121 (set spindle origin) G90 G94 G91.1 G40 G49 G17 G20 G28 G91 Z0. G90 (DRILL3) M5 T1 M6 S18000 M3 G54 M8 G0 X0. Y0. G43 Z0.6 H1 Z0.2 G98 G81 X0. Y0. Z-0.0395 R0.1999 F20. G80 Z0.6 G28 G91 Z0. G90 (TRACE1) M5 M9 M1 m2003 (LASER_VECTOR_PWM_PERCENTAGE=33.3) m2003 (LASER_VECTOR_FREQUENCY=20000) m2003 (LASER_VECTOR_GATE_DELAY=0.5) m2003 (LASER_VECTOR_GATE_DURATION=0.5) m2004 (This will Enable the Vector Laser) G54 M8 m120 (set laser origin) G0 X-0.125 Y0. G43 Z0.6 H55 Z0 G1 Z0 F30. M62 P20 (This will turn ON the Laser Gate and PWM with the next motion command) X-0.1242 Y-0.014 X-0.1219 Y-0.0278 X-0.118 Y-0.0413 X-0.1126 Y-0.0542 X-0.1058 Y-0.0665 X-0.0977 Y-0.0779 X-0.0884 Y-0.0884 X-0.0779 Y-0.0977 X-0.0665 Y-0.1058 X-0.0542 Y-0.1126 X-0.0413 Y-0.118 X-0.0278 Y-0.1219 X-0.014 Y-0.1242 X0. Y-0.125 X0.014 Y-0.1242 X0.0278 Y-0.1219 X0.0413 Y-0.118 X0.0542 Y-0.1126 X0.0665 Y-0.1058 X0.0779 Y-0.0977 X0.0884 Y-0.0884 X0.0977 Y-0.0779 X0.1058 Y-0.0665 X0.1126 Y-0.0542 X0.118 Y-0.0413 X0.1219 Y-0.0278 X0.1242 Y-0.014 X0.125 Y0. X0.1242 Y0.014 X0.1219 Y0.0278 X0.118 Y0.0413 X0.1126 Y0.0542 X0.1058 Y0.0665 X0.0977 Y0.0779 X0.0884 Y0.0884 X0.0779 Y0.0977 X0.0665 Y0.1058 X0.0542 Y0.1126 X0.0413 Y0.118 X0.0278 Y0.1219 X0.014 Y0.1242 X0. Y0.125 X-0.014 Y0.1242 X-0.0278 Y0.1219 X-0.0413 Y0.118 X-0.0542 Y0.1126 X-0.0665 Y0.1058 X-0.0779 Y0.0977 X-0.0884 Y0.0884 X-0.0977 Y0.0779 X-0.1058 Y0.0665 X-0.1126 Y0.0542 X-0.118 Y0.0413 X-0.1219 Y0.0278 X-0.1242 Y0.014 X-0.125 Y0. M63 P20 (This will turn OFF the Laser Gate and PWM with the next motion command) Z0 G0 Z0 (TRACE1 2) G0 X0. Y0.25 Z0 G1 Z0 F30. M62 P20 (This will turn ON the Laser Gate and PWM with the next motion command) Y-0.25 X-0.25 Y0. X0.25 M63 P20 (This will turn OFF the Laser Gate and PWM with the next motion command) Z0.1999 G0 Z0.6 M2005 (This will Disable the Vector Laser) m121 (set spindle origin)
