Mach4 ENUM list for mc.VAR calls: (it covers most all of the useable enums, enjoy Scott Shafer) Controller modes: mc.MC_MODE_MILL mc.MC_MODE_LATHE_DIA mc.MC_MODE_LATHE_RAD mc.MC_MODE_TANGENTIAL Axis Enums: mc.X_AXIS mc.Y_AXIS mc.Z_AXIS mc.A_AXIS mc.B_AXIS mc.C_AXIS mc.S_AXIS mc.AXIS7 mc.AXIS8 mc.AXIS9 mc.AXIS10 mc.AXIS11 Motor Enums: mc.MOTOR0 to mc.MOTOR31 Axis Bit Enums: mc.X_AXIS_BIT mc.Y_AXIS_BIT mc.Z_AXIS_BIT mc.A_AXIS_BIT mc.B_AXIS_BIT mc.C_AXIS_BIT mc.AXIS6_BIT mc.AXIS7_BIT mc.AXIS8_BIT mc.AXIS9_BIT mc.AXIS10_BIT mc.AXIS11_BIT Motor Bit Enums: mc.MOT0R0_BIT to mc.MOT0R31_BIT Spindle Control Enums: mc.MC_SPINDLE_OFF mc.MC_SPINDLE_FWD mc.MC_SPINDLE_REV mc.MC_SPINDLE_RPM mc.MC_SPINDLE_CSS mc.MC_SRANGE0 to mc.MC_SRANGE19 Getting Offsets: mc.MC_OFFSET_FIXTURE mc.MC_OFFSET_AXIS mc.MC_OFFSET_TOOL mc.MC_OFFSET_WORK mc.MC_OFFSET_HEAD mc.MC_OFFSET_ALL System Values: mc.VAL_ACTIVE_TOOL mc.VAL_AXIS_MACHINE_POS mc.VAL_AXIS_POS mc.VAL_AXIS_VEL mc.VAL_BLOCK_DELETE mc.VAL_CONTROLLER_MODE mc.VAL_CYCLE_TIME mc.VAL_DIA_REG mc.VAL_DIST_TO_GO mc.VAL_ENCODER_POS mc.VAL_EXECUTION_NUM mc.VAL_FIXTURE_POS mc.VAL_FRO mc.VAL_G_INTERPRETER_POS mc.VAL_GCODE_LINE mc.VAL_GCODE_LINE_COUNT mc.VAL_GCODE_VAR mc.VAL_TOOLPATH_PERCENT mc.VAL_HEIGHT_REG mc.VAL_MACHINE_POS mc.VAL_MOTOR_PLAN_ABS mc.VAL_MOTOR_PLAN_INC mc.VAL_MOTOR_POS mc.VAL_MOTOR_VEL mc.VAL_NEXT_TOOL mc.VAL_OPTIONAL_STOP mc.VAL_PATHGENERATE mc.VAL_REGISTER mc.VAL_RRO mc.VAL_SINGLE_BLOCK mc.VAL_SLOW_JOG_RATE mc.VAL_SOFTLIMIT mc.VAL_SOFTLIMIT_MAX mc.VAL_SOFTLIMIT_MIN mc.VAL_SPINDLE_SPEED mc.VAL_TOOLPATH_JOGFOLLOW mc.VAL_VELOCITY mc.VAL_TOOLOFFSETDIST mc.VAL_SOFTLIMIT_USED mc.VAL_SLOW_JOG_ACCEL mc.VAL_JOG_INC mc.VAL_AXIS_PROBE_POS mc.VAL_AXIS_MACHINE_PROBE_POS mc.VAL_JOG_TYPE mc.VAL_AXIS_SCALE Input Signals 0-63: mc.ISIG_INPUT0 to mc.ISIG_INPUT63 Input Motor Home 0-32: mc.ISIG_MOTOR0_HOME to mc.ISIG_MOTOR31_HOME Input Motor Pos limit 0-32: mc.ISIG_MOTOR0_PLUS to mc.ISIG_MOTOR31_PLUS Input Motor Min limit 0-32: mc.ISIG_MOTOR0_MINUS to mc.ISIG_MOTOR31_MINUS Input Signals Other: mc.ISIG_PROBE mc.ISIG_INDEX mc.ISIG_LIMITOVER mc.ISIG_EMERGENCY mc.ISIG_THCON mc.ISIG_THCUP mc.ISIG_THCDOWN mc.ISIG_TIMING mc.ISIG_JOGXP mc.ISIG_JOGXN mc.ISIG_JOGYP mc.ISIG_JOGYN mc.ISIG_JOGZP mc.ISIG_JOGZN mc.ISIG_JOGAP mc.ISIG_JOGAN mc.ISIG_JOGBP mc.ISIG_JOGBN mc.ISIG_JOGCP mc.ISIG_JOGCN mc.ISIG_SPINDLE_AT_SPEED mc.ISIG_SPINDLE_AT_ZERO mc.ISIG_PROBE1 mc.ISIG_PROBE2 mc.ISIG_PROBE3 Output Signals Limit/Home: mc.OSIG_XLIMITPLUS mc.OSIG_XLIMITMINUS mc.OSIG_XHOME mc.OSIG_YLIMITPLUS mc.OSIG_YLIMITMINUS mc.OSIG_YHOME mc.OSIG_ZLIMITPLUS mc.OSIG_ZLIMITMINUS mc.OSIG_ZHOME mc.OSIG_ALIMITPLUS mc.OSIG_ALIMITMINUS mc.OSIG_AHOME mc.OSIG_BLIMITPLUS mc.OSIG_BLIMITMINUS mc.OSIG_BHOME mc.OSIG_CLIMITPLUS mc.OSIG_CLIMITMINUS mc.OSIG_CHOME Output Signals Enable (0-32): mc.OSIG_ENABLE0 to mc.OSIG_ENABLE31 Output Signals (0-63): mc.OSIG_OUTPUT0 to mc.OSIG_OUTPUT63 Output Signals Other: mc.OSIG_RUNNING_GCODE mc.OSIG_FEEDHOLD mc.OSIG_BLOCK_DELETE mc.OSIG_SINGLE_BLOCK mc.OSIG_REVERSE_RUN mc.OSIG_OPT_STOP mc.OSIG_MACHINE_ENABLED mc.OSIG_TOOL_CHANGE mc.OSIG_DIST_TOGO mc.OSIG_MACHINE_CORD mc.OSIG_SOFTLIMITS_ON mc.OSIG_JOG_INC mc.OSIG_JOG_CONT mc.OSIG_JOG_ENABLED mc.OSIG_JOG_MPG mc.OSIG_HOMED_X mc.OSIG_HOMED_Y mc.OSIG_HOMED_Z mc.OSIG_HOMED_A mc.OSIG_HOMED_B mc.OSIG_HOMED_C mc.OSIG_DWELL mc.OSIG_TP_MOUSE_DN mc.OSIG_LIMITOVER mc.OSIG_CHARGE mc.OSIG_CHARGE2 mc.OSIG_CURRENTHILOW mc.OSIG_SPINDLEON mc.OSIG_SPINDLEFWD mc.OSIG_SPINDLEREV mc.OSIG_COOLANTON mc.OSIG_MISTON mc.OSIG_DIGTRIGGER mc.OSIG_ALARM mc.OSIG_PRTSF Tool Table Enums: mc.TOOLS_START //Start of Tools in Parameter list mc.TOOL_INC //Inc from tool to tool in the param list mc.MTOOL_MILL_X /*X offset*/ mc.MTOOL_MILL_X_W /*X Wear offset*/ mc.MTOOL_MILL_Y /* offset*/ mc.MTOOL_MILL_Y_W /*Y Wear offset*/ mc.MTOOL_MILL_HEIGHT /*Tool height offset*/ mc.MTOOL_MILL_HEIGHT_W /*Height wear Offset*/ mc.MTOOL_MILL_RAD /*Rad for comp*/ mc.MTOOL_MILL_RAD_W /*wear offset for comp*/ mc.MTOOL_MILL_POCKET /*Tool changer pocket*/ mc.MTOOL_LATHE_X mc.MTOOL_MILL_X /*X offset*/ mc.MTOOL_LATHE_X_W mc.MTOOL_MILL_X_W /*X Wear offset*/ mc.MTOOL_LATHE_Y mc.MTOOL_MILL_Y /*Y offset*/ mc.MTOOL_LATHE_Y_W mc.MTOOL_MILL_Y_W /*Y Wear offset*/ mc.MTOOL_LATHE_Z mc.MTOOL_MILL_HEIGHT /*Z offset*/ mc.MTOOL_LATHE_Z_W mc.MTOOL_MILL_HEIGHT_W /*Z wear offset*/ mc.MTOOL_LATHE_POCKET mc.MTOOL_MILL_POCKET /*Pocket # (may not be needed)*/ mc.MTOOL_LATHE_TIPRAD mc.MTOOL_MILL_RAD /*Tip Rad for comp*/ mc.MTOOL_LATHE_TIPDIR mc.MTOOL_MILL_RAD_W /*Tool tip DIR*/ mc.MTOOL_LATHE_TOOLSLIDE /*AxisSlide number and - for reversed*/ mc.MTOOL_TYPE /*Type = 0 == MILL Type != 0 == Lathe*/ Jog Enums: mc.MC_JOG_POS mc.MC_JOG_NEG mc.MC_JOG_STOP mc.MC_JOG_TYPE_VEL mc.MC_JOG_TYPE_INC ToolPath View Enums: mc.MC_TPVIEW_TOP mc.MC_TPVIEW_BOTTOM mc.MC_TPVIEW_LEFT mc.MC_TPVIEW_RIGHT mc.MC_TPVIEW_ISO Local Var Enums: mc.SV_A mc.SV_B mc.SV_C mc.SV_I mc.SV_J mc.SV_K mc.SV_D mc.SV_E mc.SV_F mc.SV_G mc.SV_H mc.SV_L mc.SV_M mc.SV_N mc.SV_O mc.SV_P mc.SV_Q mc.SV_R mc.SV_S mc.SV_T mc.SV_U mc.SV_V mc.SV_W mc.SV_X mc.SV_Y mc.SV_Z Common vars (cleared on startup) mc.SV_CMN1_START mc.SV_CMN1_END Common vars (retained across startups) mc.SV_CMN2_START mc.SV_CMN2_END mc.SV_CURRENT_TIP // Tool tip direction in Lathe mode for Tip Comp mc.SV_FRO_ON_OFF // FRO On or Off mc.SV_CUR_DIA_INDEX // Current Dia number (D) mc.SV_CUR_TOOL_NUMBER // Current tool number (T) mc.SV_CUR_SELECTED_TOOL // Current tool that is selected (Next T number) mc.SV_CUR_LENGTH_INDEX // Current Length number (H) mc.SV_CUR_TOOL_XLENGTH_REGISTER mc.SV_CUR_TOOLDIA_REGISTER // Register for the amount of tool dia offset mc.SV_CUR_TOOL_ZLENGTH_REGISTER mc.SV_CUR_TOOL_YLENGTH_REGISTER mc.SV_CUR_SPINDLE_SPEED mc.SV_TRAVERSE_RATE // Rate for traverse motions .. I don't think this is needed here.. mc.SV_FEEDRATE // Feed rate in current units/min mc.SV_ROTATION_X mc.SV_ROTATION_Y mc.SV_ROTATION mc.SV_ALM // W: Writing to this var will produce a machine alarm. mc.SV_CLOCK1 // R: Time, in milliseconds, since the machine was powered on. mc.SV_CLOCK2 // R: Accumulated time, in hours, of the machine. (Hour Meter) mc.SV_CNTL1 // R/W: bit 0 high suppresses single block (default == not set), bit 1 high suppresses waits on MST codes (default == not set). mc.SV_M_SBK mc.SV_M_MST mc.SV_M_FIN // Same as SV_M_MST. mc.SV_CNTL2 // R/W: bit 0 high disables feed hold (default == not set), bit 1 high disables FRO (default == not set), bit 2 high enables exact stop (default == not set). mc.SV_M_FHD mc.SV_M_OV mc.SV_M_EST mc.SV_SETDT // R/W: Settings Data (bit 2 = 0 Inch, bit 2 = 1 Metric) mc.SV_MSGSTP // W: Writing to this var will produce a machine stop. mc.SV_MRIMG // R: Status of Mirror Image. mc.SV_PRSTR // R: Program restart (0 or 1) mc.SV_DEFAULT_UNITS // Same as SV_SETDT R/W: (bit 2 = 0 Inch, bit 2 = 1 Metric) mc.SV_DATE // R: Current Date (YYYYMMDD) mc.SV_TIME // R: Current Time (HHMMSS) mc.SV_EMPTY // R: returns NIL mc.SV_PI // R: returns pi. (3.14159265358979323846) mc.SV_BASE_LOG_E // R: returns base of natural logarithm E. 2.71828182845904523536) mc.SV_PRTSA // R/W: Total number of parts. mc.SV_PRTSN // R/W: Number of required parts mc.SV_MAINO // Main program number. mc.SV_MOD_GROUP_1 // Group 1 // active G-code for motion mc.SV_MOD_GROUP_2 // Group 2 // active plane, XY-, YZ-, or XZ-plane mc.SV_MOD_GROUP_3 // Group 3 // absolute or incremental mc.SV_MOD_GROUP_4 // Group 4 // Arc Center mode mc.SV_MOD_GROUP_5 // Group 5 // G_93 (inverse time) or G_94 units/min mc.SV_MOD_GROUP_6 // Group 6 // millimeters or inches mc.SV_MOD_GROUP_7 // Group 7 // current cutter compensation side mc.SV_MOD_GROUP_8 // Group 8 // not used mc.SV_MOD_GROUP_9 // Group 9 // not used mc.SV_MOD_GROUP_10 // Group 10 // for cycles, old_z or r_plane mc.SV_MOD_GROUP_11 // Group 11 // Polar mode mc.SV_MOD_GROUP_12 // Group 12 // modal macro (G66,G66.1,G67) mc.SV_MOD_GROUP_13 // Group 13 // exact path or cutting mode mc.SV_MOD_GROUP_14 // Group 14 // coordinate systems (g54,g55,g56 etc) mc.SV_MOD_GROUP_15 // Group 15 // not used mc.SV_MOD_GROUP_16 // Group 16 // not used mc.SV_MOD_GROUP_17 // Group 17 // not used mc.SV_MOD_GROUP_18 // Group 18 // not used mc.SV_MOD_GROUP_19 // Group 19 // not used mc.SV_MOD_GROUP_20 // Group 20 // not used mc.SV_MOD_GROUP_21 // Group 21 // not used mc.SV_MOD_GROUP_22 // Group 22 // not used mc.SV_BUFB // last buffered D code value. mc.SV_BUFE // last buffered E code value. mc.SV_BUFF // last buffered F code value. mc.SV_BUFH // last buffered H code value. mc.SV_BUFM // last buffered H code value. mc.SV_BUFN // last buffered N code value. mc.SV_BUFO // last buffered O code value. mc.SV_BUFS // last buffered S code value. mc.SV_BUFT // last buffered T code value. mc.SV_ORIGIN_OFFSET_X mc.SV_ORIGIN_OFFSET_Y mc.SV_ORIGIN_OFFSET_Z mc.SV_ORIGIN_OFFSET_A mc.SV_ORIGIN_OFFSET_B mc.SV_ORIGIN_OFFSET_C mc.SV_LAST_OUTPUT_X mc.SV_LAST_OUTPUT_Y mc.SV_LAST_OUTPUT_Z mc.SV_LAST_OUTPUT_A mc.SV_LAST_OUTPUT_B mc.SV_LAST_OUTPUT_C mc.SV_CURRENT_MACH_X mc.SV_CURRENT_MACH_Y mc.SV_CURRENT_MACH_Z mc.SV_CURRENT_MACH_A mc.SV_CURRENT_MACH_B mc.SV_CURRENT_MACH_C mc.SV_AXIS_OFFSET_X // Used to save the offset with the G92.3 command mc.SV_AXIS_OFFSET_Y mc.SV_AXIS_OFFSET_Z mc.SV_AXIS_OFFSET_A mc.SV_AXIS_OFFSET_B mc.SV_AXIS_OFFSET_C mc.SV_CURRENT_ABS_X mc.SV_CURRENT_ABS_Y mc.SV_CURRENT_ABS_Z mc.SV_CURRENT_ABS_A mc.SV_CURRENT_ABS_B mc.SV_CURRENT_ABS_C mc.SV_G92_OFFSET_X // Used to save the offset with the G92.3 command mc.SV_G92_OFFSET_Y mc.SV_G92_OFFSET_Z mc.SV_G92_OFFSET_A mc.SV_G92_OFFSET_B mc.SV_G92_OFFSET_C mc.SV_PROBE_POS_X // G31 Skip signal mc.SV_PROBE_POS_Y mc.SV_PROBE_POS_Z mc.SV_PROBE_POS_A mc.SV_PROBE_POS_B mc.SV_PROBE_POS_C mc.SV_PROBE_MACH_POS_X // G31 Skip signal machine position mc.SV_PROBE_MACH_POS_Y mc.SV_PROBE_MACH_POS_Z mc.SV_PROBE_MACH_POS_A mc.SV_PROBE_MACH_POS_B mc.SV_PROBE_MACH_POS_C mc.SV_HEAD_SHIFT_X mc.SV_HEAD_SHIFT_Y mc.SV_HEAD_SHIFT_Z mc.SV_HEAD_SHIFT_A mc.SV_HEAD_SHIFT_B mc.SV_HEAD_SHIFT_C /* Turn Registers only */ /* G76 Parameters */ mc.SV_G76_MIN_PASS_DEPTH mc.SV_G76_FINISH_DEPTH mc.SV_G76_FINISH_PASSES mc.SV_G76_THREAD_ANGLE mc.SV_G76_CHAMFER_AMOUNT mc.SV_G76_CUTTING_METHOD /* End of Turn Registers */ mc.SV_CUR_COMP_X // Program x, used when cutter comp on mc.SV_CUR_COMP_Y // Program y, used when cutter comp on mc.SV_CUR_COMP_Z // Program z, used when cutter comp on mc.SV_G_30_XPOS mc.SV_G_30_YPOS mc.SV_G_30_ZPOS mc.SV_G_30_APOS mc.SV_G_30_BPOS mc.SV_G_30_CPOS mc.SV_WORK_SHIFT_X mc.SV_WORK_SHIFT_Y mc.SV_WORK_SHIFT_Z mc.SV_WORK_SHIFT_A mc.SV_WORK_SHIFT_B mc.SV_WORK_SHIFT_C mc.SV_FIXTURES_START // Fixture start in Parameter list mc.SV_FIXTURES_INC // (20)Increment from fixture to fixture (does not define a system var!) mc.SV_G_30_P2_XPOS mc.SV_G_30_P2_YPOS mc.SV_G_30_P2_ZPOS mc.SV_G_30_P2_APOS mc.SV_G_30_P2_BPOS mc.SV_G_30_P2_CPOS mc.SV_G_30_P3_XPOS mc.SV_G_30_P3_YPOS mc.SV_G_30_P3_ZPOS mc.SV_G_30_P3_APOS mc.SV_G_30_P3_BPOS mc.SV_G_30_P3_CPOS mc.SV_G_30_P4_XPOS mc.SV_G_30_P4_YPOS mc.SV_G_30_P4_ZPOS mc.SV_G_30_P4_APOS mc.SV_G_30_P4_BPOS mc.SV_G_30_P4_CPOS mc.SV_ROTATION_G68_NO_R mc.SV_APPROACH_DIST_X // Approch distance for the G60 Unidirectional approch command mc.SV_APPROACH_DIST_Y mc.SV_APPROACH_DIST_Z mc.SV_APPROACH_DIST_A mc.SV_APPROACH_DIST_B mc.SV_APPROACH_DIST_C mc.SV_CMN_RO_START // The starting commnon var (#500-#999) to write protect. mc.SV_CMN_RO_END // The ending commnon var (#500-#999) to write protect. mc.SV_PRTCNTL // Setting to 1 only allows M code specified by #6710 to increment part count. (default 0) mc.SV_PRTINCM // Set to a M code that will incremnt part counts with or without M02 and M30 according to #6700. mc.SV_PRTSA2 // R/W: Total number of parts. Will change/reflect #3901 as well. (cleared on file load). mc.SV_PRTST // R/W: Total number of parts machined. mc.SV_PRTSN2 // R/W: Number of required parts Will change/reflect #3902 as well mc.SV_FIXTURE_EXPAND // Fixtures after G54.1
