Summary of CMake build system results for PLplot Install location variables which can be set by the user. N.B. These variables are ordered by decreasing degree of generality, with the _default_ values of the later ones in the list determined by the values of variables earlier in the list. So, for example, it is usually sufficient in the vast majority of cases to just set CMAKE_INSTALL_PREFIX, and the rest of these variables are adjusted accordingly (at least for a fresh configuration), and it is rare indeed that is is necessary for a user to set any variable here whose name does not start with "CMAKE_INSTALL_". CMAKE_INSTALL_PREFIX: c:/Program Files/plplot CMAKE_INSTALL_EXEC_PREFIX: c:/Program Files/plplot CMAKE_INSTALL_BINDIR: c:/Program Files/plplot/bin CMAKE_INSTALL_DATADIR: c:/Program Files/plplot/share CMAKE_INSTALL_LIBDIR: c:/Program Files/plplot/lib CMAKE_INSTALL_INCLUDEDIR: c:/Program Files/plplot/include CMAKE_INSTALL_INFODIR: c:/Program Files/plplot/share/info CMAKE_INSTALL_MANDIR: c:/Program Files/plplot/share/man CMAKE_INSTALL_PKG_CONFIG_DIR: c:/Program Files/plplot/lib/pkgconfig DATA_DIR: c:/Program Files/plplot/share/plplot5.13.0 LIB_DIR: c:/Program Files/plplot/lib INCLUDE_DIR: c:/Program Files/plplot/include/plplot BIN_DIR: c:/Program Files/plplot/bin DRV_DIR: c:/Program Files/plplot/lib/plplot5.13.0/drivers DOC_DIR: c:/Program Files/plplot/share/doc/plplot INFO_DIR: c:/Program Files/plplot/share/info MAN_DIR: c:/Program Files/plplot/share/man FORTRAN_MOD_DIR: c:/Program Files/plplot/lib/fortran/modules/plplot Other important CMake variables: CMAKE_SYSTEM_NAME: Windows UNIX: WIN32: 1 APPLE: MSVC: (MSVC_VERSION: ) MINGW: 1 MSYS: CYGWIN: BORLAND: WATCOM: SWIG_FOUND: FALSE PERL_FOUND: FALSE X11_FOUND: CMAKE_BUILD_TYPE: CMAKE_C_COMPILER CMAKE_C_FLAGS: C:/MinGW/bin/gcc.exe CMAKE_CXX_COMPILER CMAKE_CXX_FLAGS: C:/MinGW/bin/g++.exe CMAKE_Fortran_COMPILER CMAKE_Fortran_FLAGS: C:/MinGW/bin/gfortran.exe Target Fortran: ENABLE_DYNDRIVERS: ON DRIVERS_LIST: mem;null;ps;svg;wingcc;xfig DEVICES_LIST: mem;null;ps;svg;wingcc;xfig Library options: BUILD_SHARED_LIBS: ON PL_DOUBLE: ON Optional libraries: PL_HAVE_QHULL: OFF WITH_CSA: ON PL_HAVE_FREETYPE: PL_HAVE_PTHREAD: HAVE_AGG: HAVE_SHAPELIB: OFF Language Bindings: ENABLE_ada: OFF ENABLE_cxx: ON ENABLE_d: OFF ENABLE_fortran: ON ENABLE_java: OFF ENABLE_lua: OFF ENABLE_ocaml: OFF ENABLE_octave: OFF ENABLE_pdl: OFF ENABLE_python: OFF ENABLE_qt: OFF ENABLE_pyqt5: OFF ENABLE_tcl: OFF ENABLE_itcl: OFF ENABLE_tk: OFF ENABLE_itk: OFF ENABLE_wxwidgets: OFF Configuring done Generating done
