Sub Main() 'Global variables declaration Dim CCWPos as Integer Dim CWPos as Integer NewTool = GetSelectedTool() OldTool = GetCurrentTool() While NewTool > 16 NewTool = Question ("Enter New Tool Number up to " & MaxToolNum) Wend If NewTool = OldTool Then'Compare between actual tool and requested tool Else End If If NewTool > 16 Then'requested tool higher then tool numbers Else End If If NewTool < 1 Then'tool number to low Else End If code("m05") Call ZatcPosition Call SpidleOrient'Activate drive spindle orient Call AtcIn'Activate air cylinder valve to put old tool back to carrousel Call Unclamp'Spindle: Tool Unclamp Call AtcDown'lowers atc Call LeastTravel'determine the least travel to move and Turns CW or CCW Call AtcUp'raises atc Call Clamp'Spindle: Tool Clamp Call AtcOut'retracts atc Call SetUserDRO (1200,NewTool)'Store new tool as actual tool value SetCurrentTool( NewTool ) End Sub Function ZatcPosition()'Move to Z tool position and wait until position reached code("G53")'Move in Absolute Machine coordinates code("G00 Z-1") 'Z value as to be checked for exact match with carrousel height While(IsMoving()) Sleep(100)'temporisation entre while++ Wend End Function Function SpidleOrient()'Spindle Orientation ActivateSignal(OUTPUT1)'Move spindle to position output# ActivateSignal(OUTPUT8)'Move spindle to position output# code("g04 p01") While IsActive(OEMTrig11)'Wait for OemTrig11 is off spindle drive oreient ready Sleep(10) Wend While NOT IsActive(OEMTrig11)'Wait for OemTrig11 is on spindle drive output Sleep(10) Wend End Function Function AtcIn()'Put old tool back to carrousel ActivateSignal(OUTPUT12)'Move carrousel air cylinder to the tool change position adjust output# to match atc slide code("g04 p01") While IsActive(OEMTrig3)'Wait for OEMTrig3 is off Mag Out Sleep(10) Wend While NOT IsActive(OEMTrig3)'Wait for OEMTrig3 is on carrousel in Sleep(10) Wend End Function Function Unclamp()'Spindle: Tool Unclamp ActivateSignal(OUTPUT13)'Release the tool, adjust output number for drawbar output ActivateSignal(OUTPUT14)'Clean tool code("g04 p01")'pause While IsActive(OEMTrig8)'Wait for OEMTrig8 is off Unclamp Sleep(10) Wend While NOT IsActive(OEMTrig8)'Wait for OEMTrig8 is on Unclamp Sleep(10) Wend End Function Function AtcDown()'lowers atc to rotate ActivateSignal(OUTPUT11)'solonoid to lower atc code("G04 p01")'pause While IsActive(OEMTrig6)'Wait for OEMTrig6 is off Mag down Sleep(10) Wend While NOT IsActive(OEMTrig6)'Wait for OEMTrig6 is on Mag down Sleep(10) Wend End Function 'Sequence to determine the least travel to move for TC, CW or CCW 'atp = Actual tool position, rtp = Requested tool positon Sub LeastTravel() NTool = 16 ' Number of tools changer holds CWPos = GetSelectedTool() - GetCurrentTool() ' Assume a CW move If CWPos < 0 Then ' CWPos < 0 ==> rtp < atp CWPos = CWPos + NTools End If CCWPos = NTools - CWPos If CWPos < CCWPos Then call CW() Else call CCW() End If End Sub Function CW()'Rotation CW Dim x As Integer Dim CTPos As Integer 'Carrousel Tool Position Relative to OldTool Position CTPos=0 ActivateSignal(OUTPUT9)'Turns the AC Motor On cw Sleep(50) For x=0 To CWPos While IsActive(OEMTrig9)'Wait for OEMTrig9 is off Sleep(10) Wend While NOT IsActive(OEMTrig9)'Wait for OEMTrig9 is on Sleep(10) Wend x=x+1 Next x CTPos=x DeactivateSignal(OUTPUT9) End Function Function CCW()'Rotation CCW Dim y As Integer Dim CTPos As Integer 'Carrousel Tool Position Relative to OldTool Position CTPos=0 Activatesignal(OUTPUT9)'atc motor revirsing relay ActivateSignal(OUTPUT10)'Turns the AC Motor On Sleep(50) For y=0 To CCWPos While IsActive(OEMTrig9)'Wait for OEMTrig9 is off Sleep(10) Wend While NOT IsActive(OEMTrig9)'Wait for OEMTrig9 is on Sleep(10) Wend y=y+1 Next y CTPos=y DeactivateSignal(OUTPUT9) Deactivatesignal(OUTPUT10)'atc motor revirsing relay End Function Function AtcUp()'MAG UP DeActivateSignal(OUTPUT11)'relay for solonoid to lower/MAG UP code("G04 p01")'pause While IsActive(OEMTrig5)'Wait for OEMTrig5 is off Mag up Sleep(10) Wend While NOT IsActive(OEMTrig5)'Wait for OEMTrig5 is on Mag up Sleep(10) Wend End Function Function Clamp()'power drawbar unactivated DeactivateSignal(OUTPUT13)'unactivating drawbar relay DeactivateSignal(OUTPUT14)'unactivating Clean tool While IsActive(OEMTrig7)'Wait for OEMTrig7 is off Clamp Sleep(10) Wend While NOT IsActive(OEMTrig7)'Wait for OEMTrig7 is on Clamp Sleep(10) Wend End Function Function AtcOut()'retracts atc deActivateSignal(OUTPUT12)'atc retract cylinder relay Mag Inn code("g04 p01") While IsActive(OEMTrig4)'Wait for OEMTrig4 is off Mag Inn Sleep(10) Wend While NOT IsActive(OEMTrig4)'Wait for OEMTrig4 is on Mag Inn Sleep(10) deActivateSignal(OUTPUT1)'Spindle Orientation deActivateSignal(OUTPUT8)'Spindle Orientation Wend End Function
