Dim x,y,z,a,b,c Dim OldTool,NewTool,tool,MaxToolNum,ToolDown,ToolUpŁ¬ToolSafe Dim Xpos,YPos Dim ToolYaxisAdd Dim BrushWaitTime,ToolReleaseWaitTime,ToolClampWaitTime 'ToolChange Macro For Bed type tool changer 11/05 Brian 'Sub Main() Code "G90" OldTool = GetOEMDRO (1200) 'Tool In spindle DRO You must add this to your settings screen x = GetToolChangeStart( 0 ) y = GetToolChangeStart( 1 ) z = GetToolChangeStart( 2 ) a = GetToolChangeStart( 3 ) b = GetToolChangeStart( 4 ) c = GetToolChangeStart( 5 ) tool = GetSelectedTool() NewTool = tool 'Tool Changer Macro (Bed Type) MaxToolNum = 6 'Max number off tools for the changer ToolSafe = GetOEMDRO (1240) 'Tool Safe Position ToolUp = GetOEMDRO (1241) '-1.0'Z Hieght to Rapid from tool to tool ToolDown = GetOEMDRO (1242) '-239.47'Z Pos to Get or drop a tool ToolYaxisAdd = GetOEMDRO (1243) '100'Y Avoid Position Add If NewTool = OldTool Then Message"Tool No Change" Exit Sub End If 'SetUserLED(53, 1) '------------------------------------------ ' Brush Control '------------------------------------------ DeActivateSignal(Output6) Message"Wait Brush Position Limit Signal " BrushWaitTime = 0 while not IsActive(Input3) Code "G4 P0.1" While IsMoving() Wend if BrushWaitTime > 25 Then DoOEMBUTTON(1021) Message"Brush Wait OverTime" Exit Sub End If BrushWaitTime = BrushWaitTime +1 wend '------------------------------------------- '------------------------------------------- Message"Tool Change" While NewTool > MaxToolNum NewTool = Question ("Enter New Tool Number up to " & MaxToolNum) Wend Code "G00 G53 Z" & ToolSafe While IsMoving() Wend Call MovePos(OldTool) While IsMoving() Wend Code "G01 G53 X" & XPos & "Y" & YPos - ToolYaxisAdd & "F5000" Code "G4 P0.1" While IsMoving() Wend Code "G4 P0.5" While IsMoving() Wend Code "G0 G53 Z" & ToolDown Code "G4 P.75" While IsMoving() Wend Code "G01 G53 Y" & YPos & "F5000" Code "G4 P.75" While IsMoving() Wend '------------------------------------------ ' Tool Release Control '------------------------------------------ ActivateSignal(Output5) 'Turn On Draw bar to release the tool Message"Wait Tool Release Signal " ToolReleaseWaitTime = 0 while not IsActive(29) 'OEM INPUT1 Code "G4 P0.1" While IsMoving() Wend if ToolReleaseWaitTime > 25 Then DoOEMBUTTON(1021) Message"Tool Release feedback Signal Wait OverTime" Exit Sub End If ToolReleaseWaitTime = ToolReleaseWaitTime +1 wend '------------------------------------------- '------------------------------------------- Code "G4 P1.0" 'Wait for the tool to release Code "G0 G53 Z" & ToolUp Call MovePos(NewTool) While IsMoving() Wend Code "G01 G53 X" & XPos & " Y" & YPos & "F5000" Code "G0 G53 Z" & ToolDown Code "G4 P.75" While IsMoving() Wend '------------------------------------------ ' Tool Clamp Control '------------------------------------------ DeActivateSignal(Output5) 'Turn Off Draw bar to Clamp the tool Message"Wait Tool Release Signal " ToolClampWaitTime = 0 while not IsActive(30) 'OEM INPUT2 Code "G4 P0.1" While IsMoving() Wend if ToolClampWaitTime > 25 Then DoOEMBUTTON(1021) Message"Tool Clamp feedback Signal Wait OverTime" Call SetUserDRO (1200,NewTool) SetCurrentTool( NewTool ) Exit Sub End If ToolClampWaitTime = ToolClampWaitTime +1 wend '------------------------------------------- '------------------------------------------- Code "G4 P1.0" 'Wait for the tool to Clamp While IsMoving() Wend Code "G01 G53 Y" & YPos - ToolYaxisAdd & "F5000" Code "G4 P1" While IsMoving() Wend Code "G0 G53 Z" & ToolSafe Code "M1801" Call SetUserDRO (1200,NewTool) SetCurrentTool( NewTool ) 'Code "G0 G53 X" & x & " Y" & y 'Move back to where the tool change was prompted While IsMoving() Wend Message"Tool Change Finish" '------------------------------------------ ' Tool Postion '------------------------------------------ Sub MovePos(ByVal ToolNumber As Integer) Select Case ToolNumber Case Is = 0 Xpos = GetOEMDRO (1220) YPos = GetOEMDRO (1230) Case Is = 1 'Xpos = 373.74 'YPos = 3393.00 Xpos = GetOEMDRO (1220) YPos = GetOEMDRO (1230) Case Is = 2 'Xpos = 573.85 'YPos = 3393.00 Xpos = GetOEMDRO (1221) YPos = GetOEMDRO (1231) Case Is = 3 'Xpos = 774.52 'YPos = 3393.00 Xpos = GetOEMDRO (1222) YPos = GetOEMDRO (1232) Case Is = 4 'Xpos = 975.84 'YPos = 3393.00 Xpos = GetOEMDRO (1223) YPos = GetOEMDRO (1233) Case Is = 5 'Xpos = 1177.93 'YPos = 3393.00 Xpos = GetOEMDRO (1224) YPos = GetOEMDRO (1234) Case Is = 6 'Xpos = 1377.14 'YPos = 3393.00 Xpos = GetOEMDRO (1225) YPos = GetOEMDRO (1235) End Select End Sub '------------------------------------------- '------------------------------------------- tool = GetSelectedTool() SetCurrentTool( tool )
