2015-12-06 15:28:39.125 - Loggging Enabled. 2015-12-06 15:29:30.078 - API: mcToolPathGenerate() called. 2015-12-06 15:29:30.187 - API: mcCntlRewindFile() called. 2015-12-06 15:30:03.078 - API: mcCntlEnable(true) called. 2015-12-06 15:30:03.078 - Signal id 1018, (Enable #0), changed from LOW to HIGH. 2015-12-06 15:30:03.078 - Signal id 1019, (Enable #1), changed from LOW to HIGH. 2015-12-06 15:30:03.078 - Signal id 1020, (Enable #2), changed from LOW to HIGH. 2015-12-06 15:30:03.078 - Signal id 1120, (Machine Enabled), changed from LOW to HIGH. 2015-12-06 15:30:03.078 - API: mcMotionSync() called. 2015-12-06 15:30:03.078 - SyncPosition()! Clearing planner. 2015-12-06 15:30:03.078 - API: mcCntlReset() called. 2015-12-06 15:30:07.640 - API: mcCntlCycleStart() called. 2015-12-06 15:30:07.750 - Attempt transition from "Idle" on event "Cycle Start" MachAPI.cpp:2420 2015-12-06 15:30:07.750 - S_IDLE_on_exit 2015-12-06 15:30:07.750 - MACH_STATE_start_cycle 2015-12-06 15:30:07.750 - S_FILE_RUNNING_on_entry 2015-12-06 15:30:07.750 - S_FILE_RUNNING2_on_entry 2015-12-06 15:30:07.750 - Signal id 1114, (Gcode Running), changed from LOW to HIGH. 2015-12-06 15:30:07.765 - Signal id 1121, (Tool Change), changed from LOW to HIGH. 2015-12-06 15:30:07.796 - Signal id 1121, (Tool Change), changed from HIGH to LOW. 2015-12-06 15:30:07.796 - Controller::RunCanonBuffer called AddStopReportRequest() RunCanon.cpp:69 2015-12-06 15:30:07.796 - Requesting a stopped report for axis 0 motors. 2015-12-06 15:30:07.796 - Requesting a stopped report for motor 0. 2015-12-06 15:30:07.796 - Requesting a stopped report for axis 1 motors. 2015-12-06 15:30:07.796 - Requesting a stopped report for motor 1. 2015-12-06 15:30:07.796 - Requesting a stopped report for axis 2 motors. 2015-12-06 15:30:07.796 - Requesting a stopped report for motor 2. 2015-12-06 15:30:07.796 - Waiting on SetStill... 2015-12-06 15:30:08.203 - Signal id 65, (Motor 0 Home), changed from LOW to HIGH. 2015-12-06 15:30:08.203 - Signal id 1002, (X Home), changed from LOW to HIGH. 2015-12-06 15:30:08.203 - Signal id 66, (Motor 1 Home), changed from LOW to HIGH. 2015-12-06 15:30:08.203 - Signal id 1005, (Y Home), changed from LOW to HIGH. 2015-12-06 15:30:08.203 - Signal id 67, (Motor 2 Home), changed from LOW to HIGH. 2015-12-06 15:30:08.203 - Signal id 1008, (Z Home), changed from LOW to HIGH. 2015-12-06 15:30:08.343 - All motors marked as still. 2015-12-06 15:30:08.343 - Waiting on SetStill is Done! 2015-12-06 15:30:08.343 - Signal id 1142, (Spindle Fwd), changed from LOW to HIGH. 2015-12-06 15:30:08.343 - Signal id 1141, (Spindle On), changed from LOW to HIGH. 2015-12-06 15:30:08.343 - Waiting for spindle at speed and stable Spindle.cpp:376 2015-12-06 15:30:08.359 - Waiting for spindle stable DONE Spindle.cpp:381 2015-12-06 15:30:08.375 - Controller::RunCanonBuffer called AddStopReportRequest() RunCanon.cpp:69 2015-12-06 15:30:08.375 - Requesting a stopped report for axis 0 motors. 2015-12-06 15:30:08.375 - Requesting a stopped report for motor 0. 2015-12-06 15:30:08.375 - Requesting a stopped report for axis 1 motors. 2015-12-06 15:30:08.375 - Requesting a stopped report for motor 1. 2015-12-06 15:30:08.375 - Requesting a stopped report for axis 2 motors. 2015-12-06 15:30:08.375 - Requesting a stopped report for motor 2. 2015-12-06 15:30:08.375 - Waiting on SetStill... 2015-12-06 15:30:10.812 - All motors marked as still. 2015-12-06 15:30:10.812 - Waiting on SetStill is Done! 2015-12-06 15:30:10.812 - Signal id 1121, (Tool Change), changed from LOW to HIGH. 2015-12-06 15:30:10.828 - Signal id 1121, (Tool Change), changed from HIGH to LOW. 2015-12-06 15:30:10.843 - Controller::RunCanonBuffer called AddStopReportRequest() RunCanon.cpp:69 2015-12-06 15:30:10.843 - Requesting a stopped report for axis 0 motors. 2015-12-06 15:30:10.843 - Requesting a stopped report for motor 0. 2015-12-06 15:30:10.843 - Requesting a stopped report for axis 1 motors. 2015-12-06 15:30:10.843 - Requesting a stopped report for motor 1. 2015-12-06 15:30:10.843 - Requesting a stopped report for axis 2 motors. 2015-12-06 15:30:10.843 - Requesting a stopped report for motor 2. 2015-12-06 15:30:10.843 - Waiting on SetStill... 2015-12-06 15:30:11.640 - All motors marked as still. 2015-12-06 15:30:11.640 - Waiting on SetStill is Done! 2015-12-06 15:30:11.640 - Signal id 1142, (Spindle Fwd), changed from HIGH to LOW. 2015-12-06 15:30:11.640 - Signal id 1141, (Spindle On), changed from HIGH to LOW. 2015-12-06 15:30:11.640 - Waiting for spindle stopped within 99% Spindle.cpp:315 2015-12-06 15:30:11.656 - Waiting for spindle stop DONE Spindle.cpp:324 2015-12-06 15:30:11.765 - Attempt transition from "File Running" on event "Stop" GcodeExec.cpp:401 2015-12-06 15:30:11.765 - S_FILE_RUNNING2_on_exit 2015-12-06 15:30:11.765 - Signal id 1114, (Gcode Running), changed from HIGH to LOW. 2015-12-06 15:30:11.765 - S_FILE_RUNNING_on_exit 2015-12-06 15:30:11.765 - MACH_STATE_stop 2015-12-06 15:30:11.812 - S_IDLE_on_entry 2015-12-06 15:30:18.718 - API: mcCntlEnable(false) called. 2015-12-06 15:30:18.718 - Signal id 1018, (Enable #0), changed from HIGH to LOW. 2015-12-06 15:30:18.718 - Signal id 1019, (Enable #1), changed from HIGH to LOW. 2015-12-06 15:30:18.718 - Signal id 1020, (Enable #2), changed from HIGH to LOW. 2015-12-06 15:30:18.718 - Signal id 1120, (Machine Enabled), changed from HIGH to LOW. 2015-12-06 15:30:18.718 - API: mcMotionSync() called. 2015-12-06 15:30:18.718 - SyncPosition()! Clearing planner.
