0
Sieg KX3 5000
MachStdMill.set
1
1
0
0
0
16
16
0
1
888
632
0
0
1
1
1
3
1
1
2
1
1
1
5
1
1
4
1
1
1
7
1
1
6
0
0
1
9
0
1
8
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1
0
1
16
1
1
14
1
1
13
1
0
0
1
1
13
1
0
0
1
1
13
1
0
0
1
1
12
1
0
0
1
1
12
1
0
0
1
1
12
1
0
0
1
1
11
1
0
0
1
1
11
1
0
0
1
1
11
1
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1
1
15
0
0
0
0
0
0
0
0
0
0
1
0
0
0
0
1
1
10
1
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1
2
4
0
0
0
1
3
5
0
0
0
1
3
6
0
0
0
1
3
7
0
0
0
1
3
8
0
0
0
1
3
9
0
0
0
1
3
10
0
0
0
1
3
15
1
0
0
1
3
12
0
0
0
1
3
13
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
2
1
0
0
1
0
0
0
1
0
0
0
1
1
0
0
0
0
0
0
0
0
0
0
0
0
0
1
1
17
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
1.000000
0
0
0
0
0
1.000000
0
0
0
0
0
1.000000
0
0
0
0
0
1.000000
1
2
2
2
3
1.000000
0
0
0
0
0
1.000000
0
0
0
0
0
1.000000
0
0
0
0
0
1
0
-1
37
39
40
38
33
34
221
219
999
999
999
999
999
999
999
999
-1
-1
-1
-1
-1
-1
2
0
0.
0.
0.
0.7
0.
0.
20.
0.0
0.0
0.0
1.0
0.0
0.0
0.0
1.0
0.0
0.7
0.7
0.2
1.0
1.0
0.0
0
1
1
40
0
1
1
0
0
0
1
0
1
G80 F125.0
0
0
0
700
1
1
20
1
0
0
0
0
0
746
0
0
0
0
1.e+005
5.8e+004
4.9e+004
7.9e+004
0.
0.
0
0
16
0
16
1
9600
1
1
0
1
10
5.
1.e+002
1.638e+004
0
64
18433
1
1
1
1
0
0
0
0
5
x
y
z
a
b
c
0
350
0
0
1
0
1
0
1.3e+003
1.3e+003
1.3e+003
0.
-1
-1
-1
-1
-1
-1
-1
-1
-1
1.e+002
1.e+002
1.e+002
1.e+002
1.e+002
1.e+002
1.e+002
1.e+003
0
0
0
522019
0
0
0
0
0
0
C:\Mach3\Addons\Newfangled\newfangled.set
0
0
0
0
7
7
9
10
0
1.
1.
1.
1.
50
0
20
0.
0.1
0.1
0.25
1.
0.3
0
0.1
0
1
5
0
5000
5000
5000
5000
100
0
0
100
0
75
75
75
20
20
20
0.5
0.5
0.5
1.
0.
0.
5.
0.
29.5
1.
1.e-003
0.1
0.1
0.1
0.
0.1
7.5
4.
8.
1.e+004
0.
0.
-7.5
-4.
-5.
-1.e+004
0.
0.
1
0
0
0
0
0
1
1
1
1
1
1
0
0
0
0
0
0
0
1
0
1
0
1
0
1
2
3
4
5
6
1
0
0
0
1
0
0
0
1
0
0
0
0
2
1.
39061
-42256
-35535
0
0
0
10
0.
0.
0.
0.
0
9600
1
0
60
0
1
0
0
0
1
0
1
0
0
1
0
2
2
0
5000
70.
0.1
0
1.
0.
0.
0.
0.
1
2.
0
0.
1
4000.
0
0.3
0
4000.
1
5.9
0
3.
0
100.
0
50.
0
2.
0
0.
0
2.
0
0.
0
3.
0
0.3
0
0.1
1
0.1
0
100.
0
0.2
0
0.
1
0.
0
0.
0
0.
0
0.
0
2.95
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
50.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
1.
0
2.
0
5.e-002
0
0.1
0
0.
0
0.1
1
36.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
1
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
30.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
1
0.
0
1.
0
1.
0
0.
0
-1.e-002
1
0.
0
0.1
0
1.e-002
0
0.
0
0.
1
0.
0
1.
1
1.
0
12.
1
0.1
0
0.
1
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
1.
1
2.
0
0.
0
0.
0
0.1
0
0.1
1
-0.25
0
0.25
1
0.1
0
0.
0
0.
0
0.
0
0.
0
0.1
0
-0.1
0
-0.1
1
1.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
1.e-002
0.1
1.
0.2
0.
0.
0.
1.
45.
6.
0.
0.
0.
1.
0.1
1.e-002
1.e-003
1.e-004
1.
0.1
1.e-002
1.e-003
1.e-004
20.
4.
0
0
0
0
0
0
C:\Mach3\GCode\76tbones.txt
C:\Mach3\GCode\Your Words Here.tap
C:\Mach3\GCode\write.tap
C:\Mach3\GCode\locowheel1.tap
C:\Mach3\GCode\pinion10.txt
C:\Mach3\GCode\New Program.tap
E:\minilocowheel1.tap
E:\miniwheel2.tap
0
*.tap
E:\miniwheel1.tap
0
0
1
Arial
Arial
Arial
5.
0.
0.
0.
0.
0.
0.
0.
0.
2
c:\mach3
0
1
1
12
1
0
1.
1
0
0.9844
7.8740157
12700.
E:\minilocowheel2.tap
E:\miniwheel1.tap
1
0.9844
7.8740157
12700.
0.6563
5.9055118
12700.
0
1.35
11.811024
10160.
0
1
2.625
19.685039
8890
1
None
0.
0
0.
0
0
0
1
0
0
0
0
Arial
0
0
0
0
5000
100
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
25000
0
0
0
10
0
0
0
0
0
0
0
C:\WINDOWS\NOTEPAD.EXE
0
Robert Clayton RZ2M
1
0
0
0
0
1
1
0
0
1
0.
0.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
1.
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0
1.3e+003
1.3e+003
1.3e+003
0
0
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
1.
0
0.1
0
2.
0
10.
0
0.1
0
1.
0
1.
1
0.75
0
10.
0
1.
1
0.
0
0.
0
21.
0
4.
0
6.
0
72.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
3.
0
0.
0
21.
0
0.
0
0.
0
0.
0
1.
0
0.19685
0
0.
0
0.
0
0.
0
1.
1
0.19685
1
0.
0
0.
0
0.
1
0.
0
0.
0
0.
0
0.
0
0.
0
0.
1
0.
1
0.
0
0.
0
0.
0
0.
1
0.
0
6129.
0
4.26
0
0.
0
2.
1
2.
0
3.
0
43.
0
22.
0
0.
0
888.
0
632.
0
1.
1
4.3380315
0
-2.6824409
0
-3.6315748
0
0.
0
72.
0
21.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
1
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
10.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
1.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
1
0.
1
0.
1
0.
1
0.
1
0.
1
0.
1
0.
1
0.
1
0.
0
0.
1
0.
1
0.
1
0.
1
0.
1
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
0
0.
999
500
100
50
400
1
ESS_v10r2d1d
1
1
1178909
255
16777215
0
0
0
0
0.5
2.e-003
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
10.9.9.9
FF:FF:FF:FF:FF:FF
250 Hz
32 kHz
32 kHz
4 MHz
4 MHz
4 MHz
4 MHz
32 kHz
In
In
0
1
1023
1
0
0
0
0
0
0
0
0
0
0
0
200.000000
200.000000
200.000000
200.000000
200.000000
200.000000
50.000000
50.000000
50.000000
50.000000
50.000000
50.000000
SD
SD
SD
SD
SD
SD
SD
1000
4.0
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
20
0
0
0
0
0
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0.000000
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
0
