'(M3332) Get Angle of Workpiece Angle = GetOemDro(118) pi=4*Atn(1) CurrentToolDiameter = GetOemDRO(43) X = GetUserDro (1053) Y = GetUserDro (1054) Z = GetUserDro (1055) CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state CurrentToolDiameter = GetOemDRO(43) 'gets the current tool diameter PlateThickness = GetUserDRO(1051) ToolLength = GetOemDRO(42) MoveXDistance = ((X * 1.1) + CurrentToolDiameter) MoveYDistance = ((Y * 1.1) + CurrentToolDiameter) MoveDistance = .5 + CurrentToolDiameter MoveZDistance = .5 If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty Call ProbeGrounded() Exit Sub Else 'Get top of part 'DoOEMButton (1010) 'zero the Z axis so the probe move will start from here Code "G4 P4" ' this delay gives me time to get from computer to hold probe in place Code "G91 G31Z-2.0 F4" 'probing move, can set the feed rate here as well as how far to move While IsMoving() 'wait while it happens Wend 'Call SetDro (2, PlateThickness) ZProbePos = GetVar(2002) 'get the axact point the probe was hit 'Code "G0 Z" &PlateThickness 'While IsMoving () 'Wend Code "G1 G91 F40 Z" &MoveZDistance 'put the Z retract height you want here While IsMoving () Wend 'Code "(Z axis is now zeroed)" 'puts this message in the status bar Code "F" &CurrentFeed 'Returns to prior feed rate 'Call SetDro (2,GetDro(2)-Z) 'Probe The X sides XCurrent = GetDro(0) YCurrent = GetDro(1) Code "G4 P1" 'Pause 1 second to give time to position probe plate While IsMoving () Wend Call SetDro (0,0.000) While IsMoving () Wend Call SetDro (1,0.000) Code "F4" 'slow feed rate to 4 ipm Rem Probe Y Face Side Code "G90 G0 X" &-MoveDistance Code "G4 P0.25" Code "G91 G0 Z" &-MoveZDistance-.2 Code "G4 P0.25" XNew = Xcurrent + 3 Code "G31 X" &XNew 'Probe X1,Y1 (P1) location While IsMoving() 'wait for the move to finish Wend X1 = GetVar(2000) 'get the probe touch location Y1=0 ' Should always be zero Y2 = Y-0.5 '1/2 inch back from end of block Code "G91 G0 X-.25" Code "G4 P0.25" Code "G91 G0 Y" &Y2 Code "G4 P0.25" Code "G31 X" &XNew 'Probe X2,Y2 (P2) location While IsMoving() 'wait for the move to finish Wend X2 = GetVar(2000) 'get the probe touch location 'Y2= Block length - 1/2 inch Code "G91 G0 Z" &MoveZDistance+.2 Code "G4 P0.25" Code "G91 G0 Y" &-Y2 'Go back to the first spot Code "G4 P0.25" Code "G91 G0 X" &CurrentToolDiameter+.1 'rapid move back to start point Code "G4 P0.25" Rem Probe X Face Side Code "G90 G0 Y" &-MoveDistance Code "G4 P0.25" Code "G91 G0 Z" &-MoveZDistance-.2 Code "G4 P0.25" YNew = YCurrent + 3 Code "G31 Y" &YNew 'Probe X3,Y3 (P3) location While IsMoving() Wend Y3 = GetVar(2001) 'get the probe location 'X3=0 X4 = X-0.5 '1/2 inch back from end of block Code "G91 G0 Y-.25" Code "G4 P0.25" Code "G91 G0 X" &X4 Code "G4 P0.25" Code "G31 Y" &YNew 'Probe X4,Y4 (P4) location While IsMoving() 'wait for the move to finish Wend Y4 = GetVar(2001) 'get the probe touch location 'X4= Block Width - 1/2 inch Code "G90 G0 Z" &MoveZDistance+1 'Back up and clear Code "G4 P0.25" t1= (x4-x3)*(y1-y3)-(y4-y3)*(x1-x3) b1= (y4-y3)*(x2-x1)-(x4-x3)*(y2-y1) ua=t1/b1 t2= (x2-x1)*(y1-y3)-(y2-y1)*(x1-x3) b2= (y4-y3)*(x2-x1)-(x4-x3)*(y2-y1) ub=t2/b2 XH=x1+ua*(x2-x1) ' X Home distance away YH=y1+ua*(y2-y1) ' Y Home distance away If X>Y Then 'LongestSide=X a=(Y4-Y3) b=(X4-X3) v=a/b NewAngle=Atn(v)*(180/pi) Else 'LongestSide=Y a=(X2-X1) b=(Y2-Y1) v=b/a NewAngle=Atn(v)*(180/pi) If NewAngle > 0 Then NewAngle=NewAngle-90 Else NewAngle=NewAngle+90 End If End If Rem move To the Block Lower Corner Code "G90 G0 Y" &YH + CurrentToolDiameter/2 Code "G90 G0 X" &XH + CurrentToolDiameter/2 While IsMoving () Wend Call SetDro (1,0.000) While IsMoving () Wend Code "G4 P0.25" Call SetDro (0,0.000) Call SetDro (1,0.000) Call SetOemDro (118,NewAngle) ' now you can rotate the block 'Call SetDro (2,Z + PlateThickness) Code "G4 P0.25" Code "F" &CurrentFeed 'restore starting feed rate Call ReturnG90G91State() Exit Sub End If Sub ProbeGrounded() Code "(Probe plate is grounded, check connection and try again)" Call ReturnG90G91State() End Sub Sub ReturnG90G91State() If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it Code "G91" Else Code "G90" End If If CurrentGMode = 0 Then 'if G0 was in effect before then return to it Code "G0" Else Code "G1" End If End Sub
