Declare Sub Sleep Lib "Kernel32" (ByVal dwMilliseconds As Long) Dim A As Integer Dim X As Integer Dim VAR As Integer Dim OldTool As Integer Dim NewTool As Integer Dim Tool As Integer Dim ZCoord As Integer SetSpinSpeed(200) SetOEMDRO(805,0) 'Set C-Axis DRO to 0 Call ToolRead Call AlignSpindle Call MoveZ Call TurnDirection Call ToolSense(NewTool) Call EndRoutine '//// Subroutines ///////// Sub ToolRead If isactive(Input1)And Not isactive(Input2)And Not isactive(Input3)And Not isactive(Input4) Then Oldtool=1 If Not isactive(Input1)And isactive(Input2)And Not isactive(Input3)And Not isactive(Input4) Then Oldtool=2 If isactive(Input1)And isactive(Input2)And Not isactive(Input3)And Not isactive(Input4) Then Oldtool=3 If Not isactive(Input1)And Not isactive(Input2)And isactive(Input3)And Not isactive(Input4) Then Oldtool=4 If isactive(Input1)And Not isactive(Input2)And isactive(Input3)And Not isactive(Input4) Then Oldtool=5 If Not isactive(Input1)And isactive(Input2)And isactive(Input3)And Not isactive(Input4) Then Oldtool=6 If isactive(Input1)And isactive(Input2)And isactive(Input3)And Not isactive(Input4) Then Oldtool=7 If Not isactive(Input1)And Not isactive(Input2)And Not isactive(Input3)And isactive(Input4) Then Oldtool=8 If isactive(Input1)And Not isactive(Input2)And Not isactive(Input3)And isactive(Input4) Then Oldtool=9 If Not isactive(Input1)And isactive(Input2)And Not isactive(Input3)And isactive(Input4) Then Oldtool=10 NewTool = GetSelectedTool() If NewTool <1 Then MsgBox ("Error! Tool "& NewTool & " Out Of Range") DoOemButton (1003) End End If If NewTool >10 Then MsgBox ("Error! Tool "& NewTool & " Out Of Range") DoOemButton (1003) End End If If NewTool<>OldTool Then Exit Sub If NewTool = OldTool Then End End Sub '---------------------------------------------------------------------------- '---------------------------------------------------------------------------- Sub AlignSpindle '-------------------- If spindle RPM =0 and Aligned ------------------------- If GetOemDro(39) <10 Then If isactive(INDEX) And isactive(OEMTRIG1) Then ActivateSignal(OUTPUT9) 'Activate Locking Pin Exit Sub End If End If '-------------------- If spindle RPM =0 and not Aligned --------------------- If GetOemDro(39) <10 Then '----M4-------- 'Start spindle CCW to brake DoSpinCCW() 'CCW Relay ActivateSignal(OUTPUT6) 'Spindle enable '-------------- ActivateSignal(OUTPUT9) 'Activate Locking Pin While Not isactive(INDEX) And Not isactive(OEMTRIG1) sleep 10 Wend '----M5-------- 'Start spindle CCW to brake deActivateSignal(OUTPUT6) 'Spindle disable DoSpinStop() 'Disable CCW Relay '-------------- End If '-------------------- If spindle RPM > 10 and not Aligned ------------------- '--------------------------- Dynamic spindle braking ------------------------ If GetOemDro(39) > 10 Then 'Get True spindle '----M4-------- 'Start spindle CCW to brake DoSpinCCW() 'Enable CCW Relay ActivateSignal(OUTPUT6) 'Spindle enable '-------------- While GetOemDro(39) > 100 'Check if spindle speed above 100rpm sleep 1 If GetOemDro(39) > 100 Then activateSignal(OUTPUT6) 'Activate Spindle ENABLE sleep 50 deactivateSignal(OUTPUT6) 'Activate Spindle ENABLE End If Wend ActivateSignal(OUTPUT9) 'Activate Locking Pin '----M4-------- 'Start spindle CCW to brake DoSpinCCW() 'Enable CCW Relay ActivateSignal(OUTPUT6) 'Spindle enable '-------------- While Not isactive(INDEX) And Not isactive(OEMTRIG1) sleep 10 Wend '----M5-------- 'Start spindle CCW to brake deActivateSignal(OUTPUT6) 'Spindle disable DoSpinStop() 'Disable CCW Relay '-------------- End If '---------------------- Double Check Spindle Index Alignment ----------------------- If Not isactive(INDEX) And Not isactive(OEMTRIG1) Then MsgBox("Tool Alignment Fail") End Sub '---------------------------------------------------------------------------- '---------------------------------------------------------------------------- Sub MoveZ code "G1 G53 Z130 F3000" 'Move Z-Axis to tool change position While ismoving() Wend deActivateSignal(OUTPUT9) End Sub '---------------------------------------------------------------------------- '---------------------------------------------------------------------------- Sub TurnDirection ActivateSignal(OUTPUT11) 'Enable C-stepper driver If OldTool < NewTool Then A= 1 If OldTool > NewTool Then A= -1 VAR= (OldTool + (5*A) - NewTool) If A= 1 Then If VAR <=0 Then X= (OldTool + 10) - NewTool Else X= (OldTool - NewTool) End If End If If A= -1 Then If VAR <=0 Then X= (OldTool - NewTool) Else X= (OldTool - 10 - NewTool) End If End If X= X*36 End Sub '---------------------------------------------------------------------------- '---------------------------------------------------------------------------- Sub ToolSense(ByVal CaseNumber As Integer) Tool = 0 Select Case CaseNumber Case Is = 1 code "G91 C" & X & "F4500" While Newtool <> Tool If isactive(Input1)And Not isactive(Input2)And Not isactive(Input3)And Not isactive(Input4) Then DoOEMButton(1003) Tool=1 End If Wend Case Is = 2 code "G91 C" & X & "F4500" While Newtool <> Tool If Not isactive(Input1)And isactive(Input2)And Not isactive(Input3)And Not isactive(Input4) Then DoOEMButton(1003) Tool=2 End If Wend Case Is = 3 code "G91 C" & X & "F4500" While Newtool <> Tool If isactive(Input1)And isactive(Input2)And Not isactive(Input3)And Not isactive(Input4) Then DoOEMButton(1003) Tool=3 End If Wend Case Is = 4 code "G91 C" & X & "F4500" While Newtool <> Tool If Not isactive(Input1)And Not isactive(Input2)And isactive(Input3)And Not isactive(Input4) Then DoOEMButton(1003) Tool=4 End If Wend Case Is = 5 code "G91 C" & X & "F4500" While Newtool <> Tool If isactive(Input1)And Not isactive(Input2)And isactive(Input3)And Not isactive(Input4) Then DoOEMButton(1003) Tool=5 End If Wend Case Is = 6 code "G91 C" & X & "F4500" While Newtool <> Tool If Not isactive(Input1)And isactive(Input2)And isactive(Input3)And Not isactive(Input4) Then DoOEMButton(1003) Tool=6 End If Wend Case Is = 7 code "G91 C" & X & "F4500" While Newtool <> Tool If isactive(Input1)And isactive(Input2)And isactive(Input3)And Not isactive(Input4) Then DoOEMButton(1003) Tool=7 End If Wend Case Is = 8 code "G91 C" & X & "F4500" While Newtool <> Tool If Not isactive(Input1)And Not isactive(Input2)And Not isactive(Input3)And isactive(Input4) Then DoOEMButton(1003) Tool=8 End If Wend Case Is = 9 code "G91 C" & X & "F4500" While Newtool <> Tool If isactive(Input1)And Not isactive(Input2)And Not isactive(Input3)And isactive(Input4) Then DoOEMButton(1003) Tool=9 End If Wend Case Is = 10 code "G91 C" & X & "F4500" While Newtool <> Tool If Not isactive(Input1)And isactive(Input2)And Not isactive(Input3)And isactive(Input4) Then DoOEMButton(1003) Tool=10 End If Wend End Select If Tool = 0 Then MsgBox ("Tool Number not Correct") End Sub '---------------------------------------------------------------------------- '---------------------------------------------------------------------------- Sub EndRoutine code"G1 G90 G53Z0 F4000" 'Move Z-Axis back to 0 pos While ismoving Wend SetOEMDRO(824,Tool) 'Set DRO with new Tool number deActivateSignal(OUTPUT11) 'Disable Turret Stepper Driver Message ("Turret Station # " & tool) End Sub doButton(0) 'Cycle Start End
